206GTI Gas Pump problem
08.05.2020 16:52 # 1
dmnbl
Hello,
LPG car does not work at all when it comes to gasoline. The engine comes to empty air and does not eat gas at all. I can handle it?
08.05.2020 16:52 # 2
muratti
Buy megane pump motor 5 bar only pump motor 50 TL. change the gas filter in one room 5 tl
08.05.2020 16:52 # 3
dmnbl
I couldn't find what you said and can I get a link if possible? 59174.html "target =" _ blank "rel =" nofollow "> I found something which would be healthier and problematic to use? dmnbl 2012-06-18 22:25:26
08.05.2020 16:52 # 4
YnsCan
[QUOTE = dmnbl]
Can't find what you say, can I get a link if possible?
well I found something which would be better to do and would it cause problems? [/ QUOTE]
my brother, it is malfunctioning to use the side industry, I am an antept, I had a problem with me. div>
08.05.2020 16:52 # 5
ozaannn
I have a problem with my friends, I did not want to open a new subject, I throw my vehicle lpgli, I do not use a vehicle for the next day, the next day the vehicle is running only one star, but it takes a long time to get started. In a short time, it is getting a mars, I did not understand it smoothly, I went to replace the spark plugs today, I told the repairman about 20 thousand.
08.05.2020 16:52 # 6
ozaannn
Don't we have any friends with knowledge?
08.05.2020 16:52 # 7
furkan111
I made 200 TL for them all ...
08.05.2020 16:52 # 8
tigerland
[QUOTE = ozaannn] Friends, I have a problem, I did not want to open a new subject, my car is throwing LPG 1 day, I do not use the vehicle the next day, the vehicle is running only one star, but it takes a long time to get started. It works as if it is okay, so it starts working in a short time, I did not understand it smoothly, I went to replace the spark plugs today, I told the repairman that it was 20 thousand. I think my problem can be a gas pump. not related to dynamo
08.05.2020 16:52 # 9
ozaannn
Mars dynamo cannot be a mars engine even if it is not strong
08.05.2020 16:52 # 10
serkandizdar
You will not be surprised by the original in the gas pump. I am not rich enough to have a supply industry .. & nbsp;
08.05.2020 16:52 # 11
roland_garros
Order oil-free contact spray from the internet, clean the throttle + idler motor + map sensor + tighten the spark plugs. Have them done, try again, if it doesn't work, open the starter 2 times, turn it on then start it, if it works, the gas pump and filter will change. I did what I said today, if this problem doesn't improve tomorrow, I will replace the gas pump.
