206cc Auto missback
08.05.2020 18:15 # 1
206cc57
Hi
My car is 206cc 1.6 automatic at 123.000 km.
About 5,000 km ago, in 2012, I changed the gearbox oil due to oil leaking from the felt.
Lately, after my car has warmed up, I have a kidnapping back to the hill and my car is moving harder even though I give off the gas to take off, I have to press more pedal. The problem disappears when I run and run it again.
It does not give automatic gear error or any other error. Only when it is cold in the mornings, it shifts from 1st gear to 2nd gear. It gets better after warming up.
08.05.2020 18:15 # 2
herry
Get past, I thought cc seeing ceiling, I looked for help. A friend who understands the problem and understands the automatic transmission helps you in the nearest time. I hope it gets fixed right away.
08.05.2020 18:15 # 3
possibly selonoid malfunction. Cellophoids work with incomplete pressure. There may also be a problem with his grip. I think the gearbox needs to be applied.
08.05.2020 18:15 # 4
206cc57
Thanks a lot in advance for the answers, it doesn't always do or I didn't realize, or it's getting tighter nowadays.
08.05.2020 18:15 # 5
mami202
without thinking the most positive zu,
For now, if the oil level of the gearbox is missing, it can be added, but I suggest you change the oil completely. If you share a positive or negative result after the oil change, we will try to help you.
