2009model failure
24.11.2020 22:51 # 1
Karahanbey
Hi, I have a 2009 model 308 and today morning when the car is cold, the fan is turned on and the engine temperature is very high STOP is displayed on the screen and the fan is constantly running. HELP !!
25.11.2020 08:12 # 2
Hello, welcome among us. Your vehicle is diesel or gasoline, sir.
25.11.2020 19:55 # 3
Karahanbey
I do not open Vti engine gasoline tube, turning on the fan when the vehicle is cold, and the engine temperature is still too high STOP!
26.11.2020 10:30 # 4
Sir, turn off the lpg system completely from its fuse. When it comes to problems, if the engine temperature is high, it is because of the heat sensor or tormostat. Unfortunately, the LPG brand does not fit all major VTI engines. The reason for turning on the fan may be due to the temperature. if there was the same problem before. Coil - may be caused by spark plugs and eccentric solenoid valves.
16.02.2021 21:38 # 5
AhmetErtas
the same incident happened to me, I went to my electrician, said the master said there is a problem in the cables, I changed the wiring. The problem has been solved, it was not possible to have a temperature failure in the cold engine. In addition, if these vehicles are to be dealt with with electrical cables, it is important to collect the cables regularly after the work is finished and leave them to their places, because it is a difficult task, the cables can swing to the right and left and break, etc., and then the master said that again.
