20 TL gasoline per week
08.05.2020 16:47 # 1
Emre GOK
Hello;
Friends, I have a 2004 model 307 xt premium automatic gear car. I have a BRC brand lpg in my car. / DIV>
Although I throw 20 TL gasoline to my vehicle every week and never use it in gasoline, it always leaves me on the road. Tools to & nbsp; I'm tired of buying gasoline and LPG finished me :( (Average fuel 11.7)
08.05.2020 16:47 # 2
metin
When you say it leaves you on the road? Do you say this because gasoline runs out and stays on the road or because the light is on?
08.05.2020 16:47 # 3
Emre GOK
The vehicle passes lpg 2 3 minutes after starting but leaves it on the road.So gasoline runs out and the vehicle does not start ..
08.05.2020 16:47 # 4
rifatseker
Gas injectors are also working along with lpg injectors. I had heard of anyone facing such a problem. As far as I remember, while the 3 lpg injector was working, 1 gasoline injector was working and the vehicle was spending on gasoline. Have a check at the lpg service.
08.05.2020 16:47 # 5
msertkol
It is also not good to buy gasoline from different places, it hits gasoline injectors. And if you travel 3-5 km a week, 20 TL gasoline is not enough per week.
Regards.
08.05.2020 16:47 # 6
Haksen016
If the vehicle is already working with gasoline at the first start and then switching to LPG, I think 20 ytl of gasoline is not so much. In the meantime, it is normal that the vehicle shows 11.7 consumption value because lpg vehicles will burn more than gasoline vehicles to produce the same job, the advantage of lpg comes from its price.
08.05.2020 16:47 # 7
sezar206
20 TL gasoline depends on usage. When you start the car, do you set off immediately, do you expect to switch to lpg? If you drive 4 - 5 km with gas in 3 minutes, it is quite normal. How many times a day you start and how much you drive it all affects the car. I have read that there are some methods to prevent this in the forum but I don't remember. According to the road he traveled, the trip computer perceived it as going with gas and dropped the needle.
08.05.2020 16:47 # 8
djchaos
absolutely gasoline and lpg are running at the same time (for a certain time) I think the car burns raw
08.05.2020 16:47 # 9
deme
Keep your tank over half the problem will be resolved
08.05.2020 16:47 # 10
OsmaN06
No, friends, my friend, if my friend is consuming the gasoline to the end, how does it not burn until now, let's discuss this issue first.? there is a job in this job
08.05.2020 16:47 # 11
hakan38
My teacher, I heard the problem of burning together. 20 TL is really a pattern every month.
08.05.2020 16:47 # 12
msertkol
Today, while going on the long road, it hit the bottom. I came home, left the things. I had to go somewhere again. I pressed the starter again, the needle came to the warehouse. I think every contact is controlling the buoy at boot.
Regards.
08.05.2020 16:47 # 13
hakan38
No, teacher, it happens occasionally.
