2.0 HDI A Few Questions - hissing and Airbag Light
24.08.2020 19:37 # 1
Outlander
Greetings, dear forum residents. Thanks to the problems under the heading I opened before, Soner, in line with the recommendations of our teacher, I do not mind much anymore :) Now, I will tell you about a situation that I started living today. I hear a hissing sound from the engine, especially from 1800-1900 rpm when I start to load on the gas while driving. You know, when the wind wanders among the trees, it makes a sound like ssssssss or exactly that. The sound stops when I take my foot off the gas. The sound starts when I start pressing the gas. I guessed like the sound of sucking air myself, but I wasn't sure. Turbo hose came to mind, but there is nothing very noticeable in performance. The interesting thing is, while the car was running, I opened the hood and throttle from the front, but I couldn't hear that sound ... When I set off again, the sound started to come back ?? I would be glad if you could help. Also, my vehicle's airbag lamp is on. It had happened to me before in a different Partner, but this light does not go out stubbornly. I checked the sockets under the seat, I tried but it didn't go out. I was suspicious of the steering wheel, but I could not see a visual problem. But again, something caught my attention in the steering area: While turning the tip of the handle for the headlights, the horn works for about 1 second, although not always. He does not say Dıt. He says “Out” and stops. I think there is a problem in the arm, but I wonder if this also affects the airbag? Thank you very much. I'm waiting for the comments of Soner teacher :) Outlander2020-08-24 19:37:50
26.08.2020 18:15 # 2
Hello, hissing sound may be coming from the exhaust. You still checked the turbo and air hoses, sir. Airbag light is caused by com2000 and will probably be corrected by repair of airbag wrapping. it is usually caused by this.
28.04.2021 20:54 # 3
Outlander
Since the neighborhood I was in was not a good master, I could only have my vehicle checked in Izmir. Soner teacher came out exactly as you said. The clamp of the turbo hose is not tightened; The sound stopped when the cuffs were tightened. Again for the airbag, the fault was caused by the winding. But I haven't got it done yet, I'm getting on that way for now. Outlander 2021-04-28 20:54:36
