2 times reduction in 206 brake hydraulic level
08.05.2020 18:30 # 1
gemlikli_55
friends, I bought a new one, the brake light started to light up 1 month ago, I searched on the internet, I learned that there was a brake fluid level decrease error, and I immediately looked at my vehicle, my brake fluid was close to the same dot number, I bought brake fluid from the same dot, I was ok until the line, the light was light, everything was normal this evening, the same brake light was the same burned immediately, I checked the brake hydraulic level, but it fell on the line of the min
brakes are holding for now, I'm going to industry
do you think why is the brake fluid poured into the vehicle decreased?
08.05.2020 18:30 # 2
ahmed206
As you know, whatever you call here is a sensitive issue, solve the event in the industry without trial and error.
08.05.2020 18:30 # 3
kursat3006
your brake hoses in the vehicle may be leaking from them. I changed it 15 days ago, the hole they removed from the war was full.
08.05.2020 18:30 # 4
gemlikli_55
[QUOTE = kursat3006] your brake hoses in the vehicle may be leaking from old ones. I changed it 15 days ago, the hole they removed from the war was full. [/ QUOTE]
What is the cost course?
08.05.2020 18:30 # 5
kursat3006
10 to 15 lira of something, only depending on the sincerity between you and your craftsman :) When the horotum changes, you will naturally receive hydraulic again. but workmanship should not be more than 20 30 lira
08.05.2020 18:30 # 6
gemlikli_55
friends I came from industry now
the right front brake hose screw was loose and was there
brake centers and hoses lining and discs are intact, even new, said the master, the problem has been fixed now
I will continue the level control again for 5-10 days, I hope there will be no problem
08.05.2020 18:30 # 7
tetik-soner
I hope it will not repeat ... get past
