2 questions in a title |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Modification and Tuning Information | |
| 08.05.2020 17:05 | # 1 |
I want to paint the 2-door glass control panel. Can I take it off at home conditions? Would it be a hot structure? Thank you guys. |
| 08.05.2020 17:05 | # 2 |
soner09 |
I am going to shine the wheels and polish them with normal skin 2 questions last day, I saw my friend 307 stuck the control panel and covered it with carbon material. div>
| 08.05.2020 17:05 | # 3 |
I will search for the brand you say thank you. I would like to know if I could easily spray it with a cloth and clean it with a cloth. is it necessary
| 08.05.2020 17:05 | # 4 |
soner09 |
walla inan I don't know that much 307 de 206, if I put the whole hole, I did it, I did it.
| 08.05.2020 17:05 | # 5 |
Can I give a detailed information to friends, I wonder if it will be possible for glass vending machines today.
| 08.05.2020 17:05 | # 6 |
fatihgg |
Let me not name, there are cleaning sprays for wheels. There are many products known by other brands in the market, etc. .. You are tightening, pressurized water and beautiful afterwards.
| 08.05.2020 17:05 | # 7 |
[QUOTE = fatihgg] Let me name you, there are cleaning sprays for wheels. There are lots of products that are known in the market, etc ... in other big markets. Waiting for detailed cvp friends
| 08.05.2020 17:05 | # 8 |
[QUOTE = hard-hungry] yeah I was going to take them from the subway, but I was still looking for them. There is an allen screw inside the handle. Then comes the pull already. After removing the electrical cable socket, you can completely remove it. That plastic is made of some strange material. In fact, the material looks ugly because it is easily injured. Once I had soaked in hot water, I heard that the soft material outside of the plastic came out and twisted on a more beautiful surface. Reviews
| 08.05.2020 17:05 | # 9 |
What do you recommend painting? Do not do sanding on the floor, do sanding on the floor, put some paint on the skin.
| 08.05.2020 17:05 | # 10 |
kaan__ |
The best solution for the rim is to squeeze out the spirit of salt and clean it with water after cleaning .... it becomes clean 2. For the glass button, there is a fine sandpaper all over, then there is a primer for the plastic surfaces, then it is the choice of glossy or matte black according to your desire. |
| 08.05.2020 17:05 | # 11 |
impact |
Well, I cleaned the glass opening control with cellulosic thinner (I learned from my fatihgg brother) I never dealt with paint etc. If it was good intention, I can explain it in detail, I could not even share the production phase because there was no opportunity ..
| 08.05.2020 17:05 | # 12 |
screw does not move from the place, I tried with all my strength in the panel, again, I couldn't
| 08.05.2020 17:05 | # 13 |
HORTLATSAK MI SUBJECT :) Guys, this glass opening control is extremely deformed. Some of the pickles are whitened. Is it enough if I remove it directly (of course :)) & nbsp; paint the plastic with a dip? otherwise, sandpaper, paint, polish etc. is it necessary ? & nbsp; I saw a few friends in the forum painted, but they did not write how that part was removed and how they were painted. I would be glad if you helped .... |
| 08.05.2020 17:05 | # 14 |
Maybe the topic in the link helps you can browse |
| 08.05.2020 17:05 | # 15 |
Friends, can you offer me an affordable product that will work? For example, do these work? http://www.hepsiburada.com/liste/motip-carat-parlak-seffaf-akrylic-vernik-sprey-400-ml-made sister-in-germany-387 227 / productdetails.aspx? ProductID = otev4048500387227 & amp; CategoryID = 20,035,769 & amp; SKU = oTEV4048500387227 div> Reviews div> Reviews div> http : //www.hepsiburada.com/liste/raymax-690c-dereceye-dayanikli-siyah-akrilik-sprey-boya-400-ml-04256424/productdetails.aspx? ProductID = otev04256424 & amp; CategoryID = 20,035,769 & amp; # SKU = OTEV04256424 forward div> Reviews div> http://www.hepsiburada.com/liste/nergis-sprey-boya-200-ml-mat-siyah/productdetails.aspx?productıd=otkrt01246& ; CategoryID = 20035769 & amp; SKU = OTKRT01246 div>
