2 questions about air conditioning and luggage
08.05.2020 18:50 # 1
HABIB1627
h. friends, i have two questions i wonder if i would be glad if you could help (2004 307 xt automatic)
1- When we press the eco button when we want it to be hot in the digital air conditioner, does the air conditioner work or gives the motor temperature, that is, is the hot air given using the air conditioner?
2- When I was driving, I pulled to the right, the baggage was not working, I stopped and opened it, while the baggage is not opened while working
thanks....
08.05.2020 18:50 # 2
serdaralisan
As far as I know, there is a security lock in the 307s, while the luggage is not opened, a system made against the possibility of opening the luggage while going to the room is a mechanism that gives both hot and cold air conditioning, not only does it give cold, but when you take it to the heat, the temperature comes as much as the temperature of your engine when you take it to the heat, it comes in the warm air produced by the air conditioner when you press the eco key. it heats up quickly or vice versa, but if your car's engine is already hot, don't press the eco button if you don't want to affect the fuel anyway, it will warm up a long way already
