2 Fault Code Printouts What Are These
08.05.2020 21:16 # 1
samizeldestan
Hello friends. In my car, 2 different codes appeared when I looked at it with 2 different programs. The first one says I think the oxygen sensor is faulty. But I don't understand the second, what does it mean?
08.05.2020 21:16 # 2
My teacher gives you such errors when your vehicle is rich or poor, such as air filter - malfunctioning map sensor, have your vehicle checked with an original software first. When was the last time your spark plugs and coils were changed.
08.05.2020 21:16 # 3
samizeldestan
[QUOTE = sonerkyl] My teacher gives this type of errors when your vehicle is rich or poor, such as air filter - first check your vehicle with an original software like faulty map sensor. When was the last time your spark plugs and coils changed. [/ QUOTE]
I don't know, I have had a vehicle for 3 months. Yesterday, I removed the oxygen sensors in the industry and cleaned them with lining spray, but I think the problem continues. If the catalyst is full, can it give errors? The vehicle sometimes falls from the traction, especially on steep ramps. But if I raise the speed from behind, the car goes like a ramp. Sometimes it happens on the plain. I hit the gas, but the car says I will not go. Do spark plugs and coils cause this problem? It's almost the same when I put the car on gasoline.
