2 amplifiers help
08.05.2020 18:18 # 1
yawruaslan
hello friends I want to connect my system to my vehicle and I want to add a few pieces on it firstly in my hand sony 4x52 output (http://morfare.com/asp/product/317/Sony-CDX-F7750B-Oto-Radyo-MP3-CD-Calar- ) I have a tape that I love, my veteran, if you throw it, it is not sold or sold, but I gave good money in good quality anyway. I have 2 legend pioneer 6985 columns and I have a Jameson usa 604 (I think mono) amphitheater. I will put hertz 30 cm bass in the trunk, I will put hertz mid team on the front doors ... now I have a mono amp for bass ... I don't have a problem for bass ... I will get a stereo amp for connecting the front mids and 6985s on the back. stereo amplifier 4 channels is enough, what do you suggest and how do I connect this mono amp and stereo amplifier They connect them to each other well, do I need anything to do this, and what do I need to put in the capacitor, and if I remember something wrong, they pull cable from the battery for some installations, what do they pull for, what does it do? thanks for comments, answers and help ...
my confirm sony xplod cdx-f7750 http://morfare.com/asp/product/317/Sony-CDX-F7750B-Oto-Radyo-MP3-CD-Calar-
amfim jameson usa 604 1500w http://www.jameson.com.tr/urun/usa-604-125.html
Maximum Power1500 Watt
RMS 4 OHM80 x 4
RMS 2 OHM140 x 2
RMS 4 OHM Mono300 x 1
Fuse 1 x 40 A
Power Cord 8 GA
Has Bass Level
the yawruasl 2014-02-16 13:46:18
08.05.2020 18:18 # 2
yawruaslan
the yawruasl 2014-02-16 13:04:50
08.05.2020 18:18 # 3
206FR
Actually, I do not need a 2nd amplifier for the installation you mentioned, but since you have a stereo amplifier because you have a mono amp, connect both of them when you come to your questions now;
1.stereo amp 4 channels is enough brand my advice if you want something high quality jbl
Example: http: //fr.jbl.com/jbl_produit_detail_fr/gx-a604.html
If you want a normal amp, if you don't remember jameson usa-505 wrong
2. They break the two amps together, usually there are 2 amp outputs behind the tapes, they bring it up to the trunk with a single cable and reproduce it with `` Y '' (the plumber adjusts the required material).
3.The part called Capacitor is a piece that balances the voltage, that is, keeps the 12volt energy constant, preventing the blinking of the headlights when you hit the bass
4. I can say that the cable pulled from the battery is the +12 volt cable, and the reason it is pulled from the battery is to be more efficient.
08.05.2020 18:18 # 4
206FR
http://www.sanalpazar.com/jameson-usa-6004-1500-watt-profesyonel-oto-anfisi__isp4900194#imgd
This is your amplifier, this is the stereo amplifier that outputs 4x350 watts with 4 channels output, and this feeds your installation completely, so there is no need for a capacitor.
08.05.2020 18:18 # 5
yawruaslan
[QUOTE = 206FR] Actually, you don't need a 2nd amplifier for the installation you mentioned, but since you have a stereo amplifier because you have a mono amp, connect both of them when you come to the questions now;
thank you for the comment i will get the stereo amplifier i will think of the capacitor
08.05.2020 18:18 # 6
206FR
[QUOTE = yawruaslan] [QUOTE = 206FR] Actually, there is no need for a 2nd amplifier for the installation you mentioned, but since you have a mono amplifier in your hand, if you have received a stereo amplifier, both of them will come to your questions now;
getting stereo amp is enough if you buy mono amp :)
08.05.2020 18:18 # 7
yawruaslan
[QUOTE = 206FR] [QUOTE = yawruaslan] [QUOTE = 206FR] Actually, I don't need the 2nd amplifier for the installation you mentioned, but if you have a mono amp in your hand, if you take the stereo amp, connect both of them and now come to your questions;
I have a link in my hand, my amp is already mono? I am wrong, I know the mono amp means bass amp, right?
the yawruasl 2014-02-16 13:20:40
08.05.2020 18:18 # 8
206FR
If the same amplifier in your hand is the one in the picture, it is not mono stereo amplifier with 4 channel output: / 206F is 2014-02-16 13:25:24
08.05.2020 18:18 # 9
yawruaslan
I have misplaced the link, I have misplaced the link of 6004 :) real link I have updated these messages :)
I took it in the picture of my amp
link >>>
the yawruasl 2014-02-16 13:47:40
08.05.2020 18:18 # 10
206FR
this is bass amp :)
08.05.2020 18:18 # 11
yawruaslan
[QUOTE = 206FR] was this bass amp:) [/ QUOTE]
yeah i knew that too then i will get stereo amp 4 channels :)
08.05.2020 18:18 # 12
206FR
Yes, you need 4 channels stereo amplifier, if you say good quality, if you say something normal, you can get jameson again.
