2.0 Hdi EGR CAN BE CANCELED?
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:42 # 1
serbayozkan
Friends I have seen in the forum that the 1.4 hdi engine was canceled by removing the egr inlet air pipe, but when I do this operation on the 2.0 hdi engine, the car protects itself and falls from traction. Can the training of
& nbsp; 2.0 hdi engines be canceled?
08.05.2020 16:42 # 2
toga406
I was wondering what is egr. Mine knows 2.0 hdi too
08.05.2020 16:42 # 3
cerci07
egr exhaust gas recycling valve
every egr is canceled 1.4 You can cancel the electronic ones from the brain by software by clicking on the pipe of the ones
08.05.2020 16:42 # 4
toga406
What is the benefit of this egr benefit?
08.05.2020 16:42 # 5
cerci07
It benefits fuel and performance, but it is not good for environment and catalyst
08.05.2020 16:42 # 6
toga406
yesterday I searched for quite a lot EGR friends, never cancel. heleki peugeots are at your fingertips in terms of electronic problem.
this thing is not very expensive, if it has a malfunction, replace it, I think it will be a benefit. provides and contributes to nature
& nbsp;
08.05.2020 16:42 # 7
cerci07
Because if I cancel the error because it is harmful to the environment, the malfunction lamp lights up, you can plug the vacuum ones into the vacuum tube. I have not encountered any malfunctions or problems until now & nbsp; As a result, it is possible to burn the non-combustible gases again and clean air enters the engine continuously.
08.05.2020 16:42 # 8
serbayozkan
When I remove the egr vacuum pipe, the vehicle protects itself and does not exceed 90 km
