1st stage fan
08.05.2020 21:25 # 1
kaan206
Stage 2 opens like fan 98. How do we know if the fan is working in 1st stage?
If the vehicle is stationary, is it understandable if we observe the fan propeller?
I think the 1st stage doesn't work, I think only the 2nd stage works
Hararet goes up to 98 and goes back to 90
Continuous decision between 99-98
What does the fan resistance do?
08.05.2020 21:25 # 2
kaan206
As a result of my research, we can find out if the fan of the 1st and 2nd stage is working.
Since the 2nd stage is audible, everyone can hear whether it is working or not. The issue was to control the 1st stage.
Turn on the ignition but do not start the engine
2- remove the brown switch socket on the thermostat
3- The fan will work as you remove the socket
4-If the fan kit freezes when it first runs, your 1st Stage fan is active
5- After a while, it accelerates and passes to the 2nd stage.
6- If the fan freezes quickly as soon as you remove the sensor, your 1st stage fan is not working. Only the 2nd stage fan of your vehicle is active.
Failure of the 1st stage fan to work allows your vehicle to warm up quickly.
