1st and 2nd gear problem
08.05.2020 14:08 # 1
bbcb
At 406 1st gear5000rpm 2nd gear 2000rpm and the engine is on load, shifting on the shift lever tremor is felt in 2nd gear more speed is between 20 and 60khm I showed 6 masters in the part we have not changed yet again shaking changing parts pressure pad lining right left flows rods rotiller engine and transmission ears 3tane gear Waiting for your help in a triangular bar where the stick and gear are connected
h_307 2010-02-18 17:02:16
08.05.2020 14:08 # 2
hasimayaz
[QUOTE = bbcb]
At 406 1st gear5000rpm 2nd gear 2000rpm and the engine is on load, shifting on the shift lever tremor is felt in 2nd gear more speed is between 20 and 60khm I showed 6 masters in the part we have not changed yet again shaking changing parts pressure pad lining right left flows rods rotiller engine and transmission ears 3tane gear Waiting for your help in a triangular bar where the stick and gear are attached [/ QUOTE]
Nothing to change from the outside anymore. After that, the inside of the gearbox .. If you see me see the complete gearbox.
h_307 2010-02-18 17:02:59
08.05.2020 14:08 # 3
bbcb
No problem with the gearbox, I looked, the flows and the ears I changed, I examined the mirror today.
08.05.2020 14:08 # 4
bbcb
Today I went to the surprise and changed the motor ear again, the result was negative, I asked the master to replace another part, he said no need to me, despite all the insistence of the master.
08.05.2020 14:08 # 5
hasimayaz
Let's say get well then. May Allah not give more trouble.
08.05.2020 14:08 # 6
bbcb
amen tsk
