1998 About 406 SV
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 15:03 # 1
SECO
Hello everyone
I just joined you with the 1998 model 406 sv. I wonder if we have a friend who can convey their features that can provide detailed information about my car. Thank you already.
08.05.2020 15:03 # 2
koliva
Hello there. You need to introduce yourself in the part of getting to know our members. Welcome.
08.05.2020 15:03 # 3
vedat ersoy
Hi ; I vedat ersoy 1997 I have a 406 sv manual vehicle I have been using it for 1.5 years, it is a very high quality vehicle with high driving pleasure. I had a problem with my car recently, the problem was stopping. I replaced the gas engine in the throttle, the problem disappeared. But there is a problem with the chock coil, while doing gas, it performs choppy and bursting. I will handle it soon.
I have a little problem. The key remote control is working sometimes, sometimes it does not work. When the keys are pressed, the light is on.
08.05.2020 15:03 # 4
vedat ersoy
hello my friend, i just joined you like i have been using it for 1,5 years 1997 406 manual sv is a very enjoyable vehicle. the quality is very high attracts everyone's attention from outside i live in çorum here like this :))) the vehicle is a very solid vehicle. My advice is to get to know a tool. In my vehicle, the engine connection wedge was broken, the guys changed the exhaust, the problem continued, and then the front team said, I rebelled enough, I finally met a master, he solves my problems now. everything is there .. regards
Vedat Ersoy
08.05.2020 15:03 # 5
GSli 406
slm vedat recommended to stay away from 406 SVs because they have electrical functions (rain sensor, heated seat, light sensor ... etc) and therefore these features often fail. I have a 2001 model 1.8 sr
(usually it goes by 1.8 h). But I went to a lot of the features of sv. Do you think I should go to sv at the first opportunity.
thanks already
08.05.2020 15:03 # 6
vedat ersoy
FIRST THANKS TO EVERYONE WHO SHARE THIS IDEAS AND INFORMATION HERE AND ALSO FRIENDS THAT OPEN THIS SITE TO SERVICE.
INFORMATION IS BEAUTIFUL AS IT IS SHARED AND GAINS VALUE.
GSli 406 FRIEND`S AN ANSWER:
MY FRIEND DOESN'T KNOW I SHALL BE NAME SHARING HERE BUT I WOULD LIKE TO KNOW EVERYONE I WRITE WITH.
IN BRIEF I EXPLAIN THE 406 SV VEHICLE AS I LIVE AND KNOW.
406 SV THE TOP SEGMENT IS VERY LUXURY COMFORTABLE VEHICLES. I THAT IS 406 SV .. HOR UNLOADED SERIOUS ACCIDENT WITHOUT A SILVER MACHINE WITH A LOW 406 SV.
SAYGILAR VEDAT ERSOY
08.05.2020 15:03 # 7
toga406
2003 I have 406 hdi automatic SV tool. I have been using it for 2 months. when I bought the fuel was a little high.
After all, I went second hand transmission oil air filter, pollen filter and so on. I changed. I had it connected to the computer and saw an abnormality in the air flow meter. When the masters did something, mixed consumption fell to 8.6. but in calm use.
Go to my Kızılcahamam. round trip 120 speed 90s. Ankara is known in traffic. 6.6 liters average.
vehicle comfort is very high. gears are so soft that they cannot be felt in calm use. manages the series according to 1410 kg. electric and heated seats are great. the side mirrors close only when manually stopped. The sound system cd is also very successful. It's wonderful to cling to the road. Especially when cornering is a really abnormal perfect. what I think is the balance bars makes this vehicle separate. heated seat is a separate comfort in snowy icy weather in winter.
Whatever happens in the coldest weather, the heater starts heating immediately. I think the fuel tank is 77 lt. 4 glass automatic. that is, show the master while buying a comfortable vehicle above expectations, if the gearbox is good and there is no major accident, paint or minor damage should not be a problem.
However, do not forget that after peugeot. Acknowledge minor electrical faults all over again. After all, it is not a zero vehicle. French is the most common situation in these vehicles.
It is slml. I can answer the question with 406 sv hdi bva as far as I know
08.05.2020 15:03 # 8
bidik55
SA FRIENDS 2003 AUTOMATIC GEARBOX IS USING 406 .. I HAVE A FAILURE IN MY VEHICLE.
08.05.2020 15:03 # 9
osman_bora
http://documentation.peugeot.com/pmdmydocfiles/doc05-01/index.html?mode=pdf&vehicule=406&lang=tr_tr&silouette=406_406&oldmode=ed
08.05.2020 15:03 # 10
osman_bora
You can access detailed information about the vehicle from the following ink.
08.05.2020 15:03 # 11
kuscu38
[QUOTE = vedat ersoy] hello; I vedat ersoy 1997 I have a 406 sv manual vehicle I have been using it for 1.5 years, it is a very high quality vehicle with high driving pleasure. I had a problem with my car recently, the problem was stopping. I replaced the gas engine in the throttle, the problem disappeared. But there is a problem with the chock coil, while doing gas, it performs choppy and bursting. I will handle it soon.
[/ QUOTE]
My friend lived in 99 polo 2 days before the trouble you said, my friend went to my electrician, the room checked the engine first, they said that the lift engine senses because it is cool, but he said he was acting late, after a little maintenance, the problem still continued. We went to an auto keymaker and explained the problem. I could not remember the name of the room battery and sensor, I made the setting and the problem disappeared. Maybe it works, but the trouble was the same.
08.05.2020 15:03 # 12
kuscu38
welcome new friends joining us. When I said to take a look at the subject, it was the meeting point for the 406 people you know :)
08.05.2020 15:03 # 13
eskihakem
Greetings, sir. I RECEIVED A NEW 406 SV 98 MODEL. LPG IS NEW INSTALLED. NOW 212 THOUSAND LPG FITTED 3000 KM. DEAD. I CHANGED OIL FELAN AFTER I RECEIVED THE CAR. I HAVE CHANGED THE SPARK PLUGS FOR SOME NEW CARE RECORDS. BOSCH BRAND DOUBLE NAIL SPARK PLUG IS OUT. IF THE MASTER GASKERS MANAGED FELAN, I HAVE CHANGED IT AGAIN. SURE BEFORE THAT THE VEHICLE WAS HAPPENING IN LPG. GIVING THE CHASSIS NUMBER FROM THE PIECE, I GET THE ORIGINAL TREATMENT BRAND SPARK PLUG. 5 TL. After replacing the spark plugs, the kickoff in the car has increased incredibly. I STARTED TO FEAR USING THE CAR. I STARTED TO SICK AND EXPLODE SOUNDS IN EXHAUST WHEN I CHANGED THE GEAR AT LOW SPEEDS. I went over this with LPG. THE PROBLEM ARE LOOKING AT THE IGNITION SYSTEM, NOT US. They told the researcher that the problem was from the ignition coil. COMMENTS THAT WERE COMMENTED, THERE ARE LOSSING BOBBIN YEARS BECAUSE IT IS USED IN THIS GAS. SOME GASOLINE DOES NOT FEEL THIS WEAK. LIGHTS OF COMBUSTION OF LPG ARE HIGHLY DEFECTING THE DEFECTIVE COIL. THERE IS INCREASING FROM LPG. WHY WHY DOUBLE NAIL SPARK PLUG? Slightly delays this beating. THE SAME BOBBIN IS LONGER EXTENDED. WE HELP YOU A FEW MONTHS. IT INCREASES BAD SIDES IN IT. NEYSE ANKARA HAS A YEAR GUARANTEED 175 TL. CHEAPED THE CHEAPEST PRICE HERE. You can investigate. I bought 4 more spark plugs, but this time I bought the BOSCH BRAND single nail original spark plug. MASTERS APPROVED BOSCH SPARK PLUG IN THESE VEHICLES. WHEN THE BELIEVE CHANGED THE BOBBINS AND SPARK PLUGS, THE CAR WAS VERY GOOD. I STARTED TO COLLECT VERY NICE AT VERY LOW SPEEDS AND FEEL THE 2000 MOTOR POWER. I RECOMMEND YOU TO CHANGE THE IGNITION COIL IF YOU HAVE A KICK IN YOUR VEHICLE.
