16lt fuel 100kmye
08.05.2020 15:56 # 1
sezar206
slm friends my car made a long road with a gas of 65 tl 300 km in the range of 100 - 130 km speed how do you think the fuel is? I went for the lpg breakdown lamp to be turned off, the master said that the gas-rich mixture burns lmbi fuel from it and also burns fuel too. Do you think there is a sanction in setting up lpg right now, I am afraid that they will spoil it. Is there any lpg you would recommend in Ankara? Thanks to everyone in advance.
08.05.2020 15:56 # 2
You even went well for 300 km 65 TL. With 2,34 liter priced lpg ..
08.05.2020 15:56 # 3
metin
I think it's normal
08.05.2020 15:56 # 4
sezar206
Thank you guys, I am very pleased with the LPG vehicle.
08.05.2020 15:56 # 5
metin
I wondered what burned it in liters. How many did you buy the lpg
08.05.2020 15:56 # 6
normal
08.05.2020 15:56 # 7
I think the value is beautiful. But it is not true that the fault light burns. If the rich is working with my wife, the problem can be solved with a shortening ...
08.05.2020 15:56 # 8
psychoabi
He said that the lamp is on me, usually when the vehicle is stationary, it doesn't matter where I get the lpg, but it does not matter, but I do not know how to prove the right way.
08.05.2020 15:56 # 9
[QUOTE = psychoabi] He said that the lamp is on me, usually when the vehicle is idle, it will not be a problem when I have the LPG, but I do not know how to do the right noble. / quote]
I mean 2.35 I suppose Göz Kırpma
60 tl lpg and 400 km very nice ... It corresponds to 6.4 lpg lpg in 100 km. When the vehicle is small and light, it is possible Gülme
08.05.2020 15:56 # 10
psychoabi
[QUOTE = CeCoLi] [QUOTE = psychoabi] said the lamp is on me, when the vehicle is generally inoperative, it will not be a problem when I have the lpg installed, but I do not know how to be the right noble of course. 4.35 TL. [/ QUOTE]
yes I would say 2.35 went to the gas my mind :)
08.05.2020 15:56 # 11
sezar206
I bought it at a price of around 2.30 pm.
last week from ankara to eskisehir air conditioner was open at 1, 90 km rarely, I went to 100 km 205 km, took 32 tl gas there.
400 km to 60 lira is very good.
If I go with the air conditioner off at a speed of 80 - 90 km, maybe I will travel about 350.
Does your car measure what burns in the city? Mine is burning 35 cents. I'm burning down, I'm falling
some of them say that they burn about 15 - 16 on 06 long 18 kuruş long roads when I compare with it. abimdee megan var 2001 1.6 16 valve we tried to burn 18 or so long way.
08.05.2020 15:56 # 12
psychoabi
My inner city is around 0.20-.022 cents yakyod I am going to increase after these increases.
08.05.2020 15:56 # 13
106_arts
well burned car
08.05.2020 15:56 # 14
mon
When the gas was 2.12, I was going to 110 km city with 20 TL. Now let's see how long it will be 2.25, the room that will go 100 km or so means 20 krş in the city.
08.05.2020 15:56 # 15
This fuel is not the same for every vehicle in the heat. The settings are very important at the mounting point. Some burns more, some burns less. The maintenance of the engine, the extras put in the vehicle, tire etc. These are very effective ... It may not always be correct for everyone to compare each other ... Our usage patterns are different, etc.
08.05.2020 15:56 # 16
metin
[QUOTE = CeCoLi] This fuel is not the same for every vehicle in heat. The settings are very important at the mounting point. Some burns more, some burns less. The maintenance of the engine, the extras put in the vehicle, tire etc. These are very effective ... It may not always be correct for everyone to compare with each other ... Our usage patterns are different, etc. [/ QUOTE]
+1
08.05.2020 15:56 # 17
hunterakon
I travel 320-350 km with a gas of 55 TL. I travel at least 30 -35 km a day in the city.
You mentioned about the malfunction lamps, mine has never burned since the day I got it, though the vehicle is kicking in gas but it still does not burn: D the hunterako 2011-08-05 13:21:41
08.05.2020 15:56 # 18
ogzhany
Hi friends, yesterday I bought a 2006 model 307 1.4 gasoline / cylinder vehicle. Atiker brand tube has been installed in the vehicle for about 7 months. I filled the gas from where I bought yesterday. I made 168 km on the long road and took 24 tons of gas. or I have a problem or something in my calculation. at the pump etc ... I could not fully understand.
08.05.2020 15:56 # 19
OkaN
how do you think this is 30 35 35 km per km in my petrolpower Embarrassed
08.05.2020 15:56 # 20
taksicicocuk
Brother, your car has burned 216,000 pounds, I think it is very good, I am a taxi driver, it does not burn so well
Page : / 2
