165.000 KM TIMING BELT IMAGE |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301 | |
| 12.09.2022 17:17 | # 1 |
what you all are wondering is when the timing belt needs to be changed. My car is 2015 301 hdi at 165,000 km, the timing service says it needs to be changed, the mileage is 165,000km or 5 years. Everyone is afraid, but do not be afraid, friends, there are 70.000 changers in 50,000, there is no need, friends, relax. |
| 18.09.2022 00:04 | # 2 |
hello trigger job is no joke, if there is an opportunity in 5 years, it would be good to change even if the km is not full
| 20.09.2022 10:11 | # 3 |
I couldn't upload the photos, it gives an error
| 20.09.2022 13:24 | # 4 |
Well, my friend, I don't know your car, but I had to change it at 53000 km because the idler tensioner was making noise, it was rattling like crickets. .
| 26.09.2022 12:53 | # 5 |
If there is no problem with the tension rod, tension ball and the circulation pump is not leaking water, I agree with the friend. When I complete 5 years, I will remove the timing cover and check it myself. Due to experience, the timing belt that I changed was just like the first day because the constant was filled only by year.
| 10.05.2024 22:20 | # 6 |
Hello, my car has 141,000 km. The timing belt hasn't been changed at all. It seems to be fine, but the mechanic said that if the timing belt breaks, you'll have to pay 1,000 TL for a tow truck and 10,000 TL for repairs. I looked today. The original price for the timing belt plus the recirculation pump is 3,900 TL. There are also those for 3,000 TL. https://www.otoyedekmarket.com/kategori/peugeot-301-triger-seti-ve-devirdaim-yedek-parca-fiyatlari, but I'm still thinking of using it. If the belt can run without breaking, I'll replace it around 160,000.
