1.6 vti engine oil burning problem
27.12.2021 16:04 # 1
ercanayman
Hello,
There is a 1.6 Vti engine oil burning problem. It did not pass the exhaust inspection.
How much would an engine revision cost if I tried to have it done?
Master who will give information is there?
29.12.2021 10:14 # 2
Hello. Is there lpg in the car? I would recommend you to have it looked at by a good master before getting into the engine. get an engine compression measurement and change the spark plugs every two services. You have to sacrifice 20000 TL for engine overhaul, unfortunately. If you are in Istanbul, youtube recep master repair house (erciyes oto) has made a bmw there, a few of them have a nice workmanship, the same engine as bmw, only yours does not have a turbo. I recommend you to use quality oil, especially in vti engines.
23.01.2023 15:45 # 3
mehnasa
I have oil burning problem in my car too. It gives off blue smoke when I give it gas. What is the estimated cost? I would be very happy if you recommend a good master for this job in Manisa or İzmir.
11.03.2023 02:18 # 4
Mido5756
There was blue smoke in my vehicle, too, I drove it for about 3 thousand km, I changed the pcv valve, but in vain, the engine stopped by itself and went and did not even say goodbye. /div>
I am in search of a good master. Cities I can take to Gaziantep, Manisa
