1.6 VTI AL4 not eating gas
27.08.2021 15:13 # 1
rodrunner
One week after the coil and spark plug change, my 2008 model vehicle started not to eat gas. I left it to the industry today. The vehicle has not been looked at yet, so I am opening the subject because I will write the steps. Of course, I am waiting for the next week for the clear result. Good luck.
28.08.2021 13:21 # 2
sozuak
Spark plug may be loose. There may be a problem with the ignition. (Spark plug, cable, coil may be defective)
06.09.2021 22:48 # 3
rodrunner
The vehicle was left at the mechanic for a week and the fuel pump was changed along with the sente adjustment. After a while the same problem started again. The car already had lpg. I'm going to do a catalyst check. During takeoff, it looks like someone is holding it and suddenly accelerates.
06.09.2021 22:49 # 4
rodrunner
I don't know if it's related to this, there is a sound like a ball bearing from the right side while driving at low speed.
07.09.2021 08:52 # 5
Toprak63
Did you solve it, what is the latest situation?
08.09.2021 12:11 # 6
rodrunner
Unfortunately it was not resolved and it got worse. Two days after I bought the gas from the mechanic, it started doing it again and stopped on the road yesterday evening. It didn't start again, but the engine was not working. We left it to the mechanic with the tow truck again. Let's see what will happen. By the way, yesterday it also gave the warning that the eco mode is active. I will share the developments.
Actions done so far are respectively;
1.Coils and spark plugs replacement
2.Oxygen sensor replacement
3.Sente adjustment< /div>
4.Float change
5.Electrovana has also changed something, I don't quite understand
08.09.2021 12:12 # 7
rodrunner
By the way, I was 7 in two weeks regarding the transactions I mentioned. Let's see what will happen next.
11.09.2021 12:26 # 8
rodrunner
I think the problem is solved. We changed the buoy again. I didn't have any problems for 25 km.
11.09.2021 21:54 # 9
Speedrun
My master also bought the vehicle recently. There was a problem of not eating gas and working late in my vehicle, first the electrical installation was checked, there was no problem there, then the spark plugs were changed, he said, he jumped to the cent, the master said that the cent was adjusted, it is still working late, but it is still a little suffocating 130 uda does not pass, if I can not fix the car, I will sell Bi Do you have any suggestions, by the way, the vehicle is LPG 110 luk Vti comfort, thanks
