1.6 Hdi idling shudder
16.04.2021 00:26 # 1
a.kadircinar
Hello friends,
For the last 1 month, there is a subtle tremor in the place where the vehicle stops, regardless of whether the engine is hot or cold.
No malfunction lamp lights up.
I can think of an injector or throttle valve, has anyone had an idea or happened to it?
16.04.2021 00:37 # 2
ProZodiaC
There was a similar problem in my vehicle when I started the vehicle, a little shaking from the seat I was sitting on was a jolt when I turned off the vehicle, the problem was solved when the motor lug was changed.
29.04.2021 20:50 # 3
a.kadircinar
Hello, I have looked at the engine ears, no problem. 90 percent of the car to be maintained, I will write here when the injector is done, let's see it. would be
18.03.2025 23:48 # 4
fcesur77
Hello. What's the problem, sir? I have the same problem. The vehicle vibrates at idle, and the vibration increases when stopped due to the steering wheel and glass consuming power from the engine.
