15 cents at KM?
08.05.2020 20:51 # 1
TugbayDundar
Hello friends,
My vehicle normally burns gas between 23-25 cents per km. I make 400-420 km of urban-long road mixed with 1 warehouse. Tank volume 33 liter gas price: 2.89
I filled the tank for 95 lira. I traveled 215 km and the lpg light fell to 1 level. I fullet the tank again because I will go the long way. I paid 31 TL. So I made 215 km to 31 TL. This corresponds to 14.4 cents per km. Does anyone have the idea how something like this could not have burned so little?
Thanks
Brc brand LPGli 206 quiksilver 1.6 engine
08.05.2020 20:51 # 2
kayaca
I also have a problem, I have a problem.
08.05.2020 20:51 # 3
KILIC
There may be a problem with the gun in the place where you received gas. It may be overprinting, it may be showing less :)
08.05.2020 20:51 # 4
maximusti
If the car burns like that, is it for sale :) :)
08.05.2020 20:51 # 5
recepagdas
you are making a wrong calculation because At each station in each of the stations, it is different that each pump will cut the gas at the pressure of the bar. While one station throws 50 lira, the pump of the other station is set higher. What matters is when the gas ends with the liter it takes. Take 50 lira and calculate when the gas runs out In fact, even this may differ, if there is a gas that you can go at 10 km e5, if you go to the gas while a little slope comes out, then the car will turn over and gasoline. But when you are going on the straight road, you will gas again. You will go another 10 km. But at least the closest measurement is done in gas. so you measure with your car's gas brain, not with the pump's beating. since each pump is in different setting.
08.05.2020 20:51 # 6
x571
[QUOTE = TuğbayDündar] Hello friends,
Thanks
See how many liters of gas you get from the gasoline plug. calculate that way. some pumps press 28 to 35 liter tank, others press 32-33.
08.05.2020 20:51 # 7
kayaca
But there is a situation, it takes 22 liters in 62 liras, it takes 28 liters in 82 liras, but sometimes it is a problem in the warehouse or somewhere else, it is 200 km at 62 liras, while it is at 290 liras at 82 liras, it is going to be over pressed or taking, according to what it does not take from the tank. I think he is doing it on the other hand?
08.05.2020 20:51 # 8
x571
[QUOTE = rock] but there is a situation, it takes 22 liters in 62 liras, it takes 28 liters in 82 liras, but sometimes there is a problem in the warehouse or somewhere else, it is over 200 km at 62 liras, it goes 290 km at 82 liras, or how much it is pressed. On the other hand, I think that he is buying it from the tanker, what is he buying? [/ QUOTE]
If you are picking up from the same place, when the tank is finished, there is a butterfly. it came to me like this, normally the tank takes 29 liters. I make 490 km out of town for 29 liters. When I moved, I bought it from another place and they started to press 32-33 liters to the tank, but the mileage I stayed remained the same. I found a neat station to the experiment. If you ask, everyone wins halal.
08.05.2020 20:51 # 9
bilo131
Did I travel 215 km in the city or on the long road. So by looking for the signs on the long road, you can estimate how many kilometers you traveled. While the city has not done so many kilometers, the meter may have counted incorrectly and may be due to km sensor. An estimate only
08.05.2020 20:51 # 10
x571
Thanks
The best method of understanding is to make the filling after the gas is full and passes to gasoline. Even if you go with a fixed 70-80km, you can find out how much the vehicle is driving at the most economical.
08.05.2020 20:51 # 11
TugbayDundar
After finishing the warehouse until the end of the weekend, I bought 25 TL gas for trial purposes.
(1LT: 2.89) After leaving 120 km, the gas is completely gone. This time he burned 21 cents per km. I have not exceeded 90 km.
As you said, it is likely that the pump setting has changed. Since he filled the tank with 4-5 liters, I thought I was a full person.
08.05.2020 20:51 # 12
kayaca
[QUOTE = x571] [QUOTE = to rock] but there is a situation, it takes 22 liters at 62 liras, it takes 28 liters at 82 liras, but sometimes there is a problem in the tank or somewhere else, it has gone 290 km at 82 lira and 62 km at end. On the other hand, I think that it is overprinting or buying according to what it does not, but it does not take it from the tanker. [/ QUOTE]
There is something odd, let's see, good luck, I leave without leaving any gas in the tank. I always take it from the same place.
08.05.2020 20:51 # 13
x571
[QUOTE = rock] [QUOTE = x571] [QUOTE = rock] but there is a situation, it takes 22 liters at 62 pounds It takes 28 liters at 82 pounds, but sometimes it is a problem in the tank or somewhere else, it ends at 200 km at 62 pounds 82 On the other hand, I think 290 km has gone in lira, what is it that is overpressed or it is not buying or it is not taking it from the tanker. [/ QUOTE]
Check the km you traveled. worst 60-70 km over the same 6 liters
08.05.2020 20:51 # 14
kayaca
Exactly, I will try this day, I'll be more full, 210 km went red, but it is going, let's see how much
