1.5 bluehdi audio work problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2016-)
03.12.2020 23:27 # 1
Ozdemirli
Hello everyone, good forums ... I had the first maintenance of my 3008 1.5 blue hdi vehicle at the authorized service. Engine noise increased significantly after maintenance. The motor, which used to be thicker and quieter, now started working louder, like a trot. I hear a high-pitched sound like injector clicking at some revs. Even if the engine is warming up, it works noisy It was not like that before maintenance. I think it's about oil. The answers I got from some 3008 users are that the factory oils are 0W30, but 5W30 oil is added after the instruction to the services. I don't know if this information is correct, but do you think this oil type makes the engine run louder? The engine oil information on the invoice is as follows: INEO 5W30 HTC - B71 2297
04.12.2020 23:20 # 2
bursae16
The engine oil recommended by the factory for your vehicle is Total Quartz İneo First 0w30 and its market is around 250 TL. Engine oil definitely affects the operating sound What is shown with the letter W is the resistance to viscosity, ie fluidity. 0W30 oil is more fluid than 5W30 oil, especially when the engine is cold. In other words, thin oils with low viscosity flow more easily and are more fluid to protect the engine at low temperatures. As you know, the difference between engine noise and working efficiency becomes clear in winter months. My recommendation to you is to put the Total Quartz İneo First 0w30 oil recommended by your factory. Good forums ..
19.01.2021 20:02 # 3
Ozdemirli
Thanks for the answer. However, although I openly asked the service, the factory did not say it would put 0w30. I even heard that the factory made a filling oil, then it would not serve the same oil.
A friend of mine, He said that the service offered an option for the oil to be put in the vehicle and put the oil selected according to the customer's decision into the vehicle. It even showed me that there is a price for two different oils with the "get offer" option in the MyPeugeot application.
When I had my first maintenance done in an authorized service in Istanbul last November I was not asked such a thing. From this point on, I think there is no standard in services.
I'm still searching for the right information. Unfortunately, since the brand does not clearly say that this type of oil is used in the user manual (they can make changes over time and that information is out of date), it is true, I did not know who to ask. Where did you get the information that the factory recommends 0w30 oil? Maybe I will reference that source and object to the service. But all services put 5w30 oil on AdBlue vehicles, I do not know how to get it accepted.
03.02.2021 18:03 # 4
Ozdemirli
Today I used another 3008 1.5 diesel EAT6 on loan. His engine sound was the same as in my vehicle. I started to accept this sound as normal.
