15/40 engine oil ..
08.05.2020 16:24 # 1
Ucyuzalti
I wish everyone good night, I will ask you something:
& nbsp; Friends I use castrol 10-40 in my 306 griffe vehicle. I am very pleased with the traction of the vehicle but there is a lack of engine oil in LPG, it seems like it does not exist in gasoline or less.
& nbsp; It is appropriate for me to put 15/40 on this vehicle after writing 10-40 on this vehicle. What would be the payoff?
& nbsp; The maximum value that will be reduced in the manual of the vehicle is 500mg / 1000km, there is about 400 mg decrease in use with lpg.
& nbsp; & nbsp; & nbsp; Reviews
08.05.2020 16:24 # 2
djchaos
I would be surprised by the oil proposed by the factory.
08.05.2020 16:24 # 3
sahin-peugeot
Putting 15w40 too thick will damage you continue to the engine 10w40
08.05.2020 16:24 # 4
Ucyuzalti
Well then 10-40 continue, there is a cheaper, quality cappuccino oil from castrol & nbsp; "LOL" & nbsp;
08.05.2020 16:24 # 5
djchaos
[QUOTE = Three Hundred Six] Hmmm then 10-40 continue, there is a cheaper, quality cappuccino oil from castrol & nbsp; "LOL" & nbsp; [/ QUOTE]
There is
but quality is definitely castrol magnetic calculating 3 cents and being 5 cents & nbsp; "Wink"
08.05.2020 16:24 # 6
Ucyuzalti
Let the quality get stuck on the peugeota then & nbsp; "LOL"
08.05.2020 16:24 # 7
djchaos
When I bought my car, I had LPG oil, the oil came out like black coal, I canceled the tube, and I did not use any oil other than castrol magnetic, I started to change my oil before the oil change time. I observed that there is really good quality oil in my opinion.
08.05.2020 16:24 # 8
ugur_clskn
I used it from the same vehicle, my friend was LPG and mine was an oil extubation. There are 10 60 oils in mobile, fully synthetic, you can try to reduce the extract, which is very low in me.
08.05.2020 16:24 # 9
Ucyuzalti
mobile 10 60 I have researched this oil very well, you have a good person who says that it is bad and it is ready to put it in the same car. How did it change according to the performance performance of 10-40? & nbsp;. I even read your subject, you were asking in the forum. "border =" 0 "alt =" LOL "title =" LOL "/>
< edited> Üçyüzaltı 2011-11-29 23:49:10
08.05.2020 16:24 # 10
Ucyuzalti
But there is this, contrary to what everyone knows, if the oil does not darken, it does not darken because it does not do its duty, darkening oil is good "LOL" It is very light color I know it doesn't mean anything, die
08.05.2020 16:24 # 11
djchaos
not very clear used oil color has a dark color but after lpg the first oil change like coal, after the first oil change you did not know at most 300 after 500 km, the oil is same color like coal. good
08.05.2020 16:24 # 12
Ucyuzalti
Hmm, that situation is different, so the engine is filled with a lot of sediment & nbsp;
08.05.2020 16:24 # 13
djchaos
LPG on the top of the pistons binds soot & nbsp;
08.05.2020 16:24 # 14
Ucyuzalti
Our ancestors were able to pick up the timbered mustard, look at how many cylinders I was riding now, we wouldn't be dealing with air gas & nbsp; "LOL"
08.05.2020 16:24 # 15
mhakan71
friends, I am waiting for your comments about 10/60 oil, as a result of my research, this oil is a little expensive but I heard that it is very successful in vehicles with oil reduction and LPG.
08.05.2020 16:24 # 16
Ucyuzalti
Exactly nothing in gasoline oil eksiltio 10/60 really good in lpg?
08.05.2020 16:24 # 17
sahin-peugeot
[QUOTE = djchaos] [QUOTE = Three hundred below] Hmm, then 10-40 continue, there is a cheaper, high-quality sugar with castrol & nbsp; "LOL" & nbsp; [/ QUOTE]
but there are definitely castrol magnetic calculations of 3 cents and 5 cents in quality & nbsp; "Wink"
& nbsp;
brother see your & nbsp; car I want, give the most expensive oil, you are using the original of every piece, I appreciate you & nbsp; & nbsp;
& nbsp;
& nbsp;
08.05.2020 16:24 # 18
maestro
I also had a fat reduction about a thousand km ago I put 10-60 oil on mobile, after long & nbsp; research I decided this. I can't say anything about & nbsp; the effect of oil reduction at the moment but I thought that it could be one of the gaskets because there was no blue smoke in my car & nbsp; it is said that this oil reduces filling and decreases oil reduction since it is 10-40 different. Another difference of 60 to 10-40 is that the oil is more intense when the engine is cold. so I think it would be better to try this oil in the summer because especially in the mornings, the sound of the engine is quite high.
