1.4 shaking problem during hdi cruise
11.02.2022 11:06 # 1
heavyburak26
I have a 2003 model 1.4 hdi 206 at 250000 km. >
is making a shaking-style movement.
at that time from the engine (it makes a sound like a high gear low speed up - throat cleaning sound)
crank sensor fuel filter injectors I had them all looked at
no problem
Is anyone else having the problem
11.02.2022 15:21 # 2
Have you cleaned the air flow meter and throttle body?
14.02.2022 07:59 # 3
heavyburak26
yes it's done
more on the slightly inclined ramp up the road at 2000rpm.
it seems like it's getting dirty diesel.
14.02.2022 11:11 # 4
If previous owners bought fuel from bad places, excessive dirt may have accumulated in the tank. but if it is doing uphill, it may be making the fuel system air. Is the fuel filter original? unfortunately, there are fake products in the market
14.02.2022 11:39 # 5
heavyburak26
I always used original parts
14.02.2022 11:47 # 6
Well, sir, then the thing to do is my opinion, of course, it is necessary to connect the vehicle with the original software and check the injector values ​​on the road, the turbo values ​​of course, it is difficult to find a master who will do this. doing it while climbing a slope is as if water has accumulated somewhere and it touches something while going uphill and makes a short circuit. strange situation. First of all, sir, get a couple of oil-free control sprays. A cleaner used for cleaning electronic boards and sockets. nice sockets etc. clean it and check the pins. an attachment in the cables that catches your eye, etc. see if there is. Has something like a xenon sound system been made to the car? This type of problem even occurs when careless masters brutally cut the cables and use only tape without making a lewd, and cause it to oxidize while performing such operations.
14.02.2022 12:51 # 7
heavyburak26
You need to look at the master work you mentioned. but there is no short circuit etc. in the remaining places
let's see the car I'll show to the plumber
16.02.2022 17:29 # 8
yunusalidem
Could it be possible to make it from the deposits in the fuel tank?
This is what came to my mind if you had all the systems renewed. If the fuel level has decreased, I think it may misfire due to sedimentary fuel. There will be less trouble when the tank is full.
17.02.2022 13:48 # 9
heavyburak26
Well sir,
I went to İzmir 5th Industry pejo service yesterday
Brake seal changed
It seems to be the reason
I couldn't complete the full test
I'll let you know when it's done
19.02.2022 06:22 # 10
heavyburak26
the problem was with the brake switch
the car was making a very short hold on the inclined place
did the ramp show the error in a more specific way
We solved the problem with 100tl brake switch for 50tl labor
thanks for your effort
24.03.2022 11:07 # 11
heavyburak26
In addition to the brake switch, there was also a problem with the rear torsion... the problem was completely solved.
21.04.2022 09:09 # 12
mehmettsener
Hello, what is the name of this service?
22.04.2022 08:53 # 13
heavyburak26
on the izmir fountain side. peugeot service
0232 479 22 19
ask master Sinan
