14 hdi users a Rica
08.05.2020 15:52 # 1
Friends, one of the last master confused.
08.05.2020 15:52 # 2
Let me check it out after using it, but what you said is correct, that is, if you increase the temperature of the fluid in a closed system, its pressure will increase.
08.05.2020 15:52 # 3
thank you in advance bro
08.05.2020 15:52 # 4
mon
the same problem is also in my car when the lpg li haretet 90 becomes, the hose at the upper inlet of the radiator hardens.
08.05.2020 15:52 # 5
I think this is not a problem, but the master confused me, just opened the lid of the water tank, it was bubbling, he put some water on it, I know that there was damage, he said it was not open to open the lid when it was hot. this situation has not been
08.05.2020 15:52 # 6
Because the damage of opening the lid when it was hot was pressurized, I think it was things like hitting the lid on the face, hot water gushing, scalding etc. I also know that it can cause thermal stresses in very hot tanks and cold water materials.
08.05.2020 15:52 # 7
berk2309
If you open that cover while the water is boiling while the engine is hot, you will be as if you have touched it on your face, and if you put cold water on the heated water, it can be killed. In the car that is overheated, you will get the engine or radiator cold and water will be touched.
08.05.2020 15:52 # 8
berk2309
In addition, if there is no heat problem in the car, it does not cause any problems. Also, the car with air in the system makes the roof ceiling already.
08.05.2020 15:52 # 9
I know the explosion event when I first got the driver's license, it happened to me, I opened it consciously, but I burned my arm anyway, I don't think there will be a bit of a trace. I fall back in 97, circulation is open I guess they have never risen so far over temperature
08.05.2020 15:52 # 10
berk2309
If there is no temperature in the ceiling, there is no air in the system, it does not recirculate, but the wrong information is given.
08.05.2020 15:52 # 11
I think the fan meant to open 97dem in the fan?
08.05.2020 15:52 # 12
berk2309
Mine is not diesel, but I have 97 deaf and I have a peugeot boxer, it always stops at 90. Have you changed the recirculation thermostat before?
08.05.2020 15:52 # 13
I did not change, but the complete engine was built at the end of the car last summer. Is thermostat my instrument measuring the temperature you call?
08.05.2020 15:52 # 14
berk2309
Yes, the thermostat measures the temperature of the water and turns on the fan.
08.05.2020 15:52 # 15
It can be said to be reliable, but I would change it anyway, it is not a very salty piece.
08.05.2020 15:52 # 16
vbmaster
teacher, don't forget, 20-30 lira.
08.05.2020 15:52 # 17
berk2309
If you buy the original thermostat, it would be 50 to 70 something, you will probably get a ruffle.
08.05.2020 15:52 # 18
I will mend at the first opportunity, but I do not think I can go up to 20 30 lira.
08.05.2020 15:52 # 19
berk2309
Do not look at the masters, they get money for workmanship, always problem 20 30 pounds more than 100 150 find this process
08.05.2020 15:52 # 20
I ask if it has changed then no need to change it but antifreeze in the car, I know it.
Page : / 2
