123456
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106
08.05.2020 14:57 # 1
Guests
Kozolaq 2017-11-17 19:20:25
08.05.2020 14:57 # 2
ali oncu
I do not think it will be a big problem, but in general, it will be useful to have it connected to the PC. I think it might have been made from fuel (lpg). Of course, this prediction will help more experienced friends.
08.05.2020 14:57 # 3
Guests
I am waiting for your help on the subject, friends
08.05.2020 14:57 # 4
Onur
It is most likely due to LPG spark plugs, if there is a problem, then it may burn.
08.05.2020 14:57 # 5
aktifoto
IT WILL FLASH BETWEEN AND THE WORK OF THE VEHICLE IS PROBLEMS If LPG FROM LPG TO PEUGEOT LAR LPG DO NOT KNOW THAT KNOWS KNOW IT BECOMES IMMEDIATELY LPG COMES TO US.
08.05.2020 14:57 # 6
GiTaRRa
friends, I have the same problem, but I do not have lpg in the car
08.05.2020 14:57 # 7
Guests
Let the feast be put off, the services will be closed to the PC, even if there are such minor problems, it is disgusting.
08.05.2020 14:57 # 8
jhonny_cage
slm friend, the lamp in the picture usually turns on the pc as a catalytic converter, but when maintenance is done, the injectors can be clogged instead of the catalytic converter.
08.05.2020 14:57 # 9
suleyman
What did you do? The problem has been solved ... I had the same problem and burned again
08.05.2020 14:57 # 10
OkaN
Did you check the water of the vehicle
08.05.2020 14:57 # 11
psychoabi
I have the LPG gas setting is broken, the car is on the stationary circuit, the lamp is connected to the computer and the gas settings are changed. Now the fault lamp is not burning.
