106xs engine malfunction light is on and not working
08.05.2020 13:59 # 1
Hello everybody,
98 models have 106 xs im
when I turn the ignition in the last days, the engine fault light does not illuminate, when it does not illuminate, the starter is pressed but the vehicle it does not operate does not start. I turn the ignition off and on after a few times the light comes on and works. light turns off after working. (normal operation).
The light winking on the way, the vehicle continues to sing. Stopped 1 time.
I am waiting for your ideas, suggestions of a good master I can show the fault in Izmir.
thank you.
08.05.2020 13:59 # 2
sinan-s
Welcome to the club..
What is the problem of having the vehicle connected to the machine in the authorized service ...
08.05.2020 13:59 # 3
I took it to the service and the electrician. "Let's make a new chip," he said. but I also tried with a spare key. he does the same problem. I said not from the ignition key. When I insisted I did not continue. Then I took it to the service, the service could be from the brain, let the car go and try to insert the brain.
08.05.2020 13:59 # 4
sinan-s
It has nothing to do with your contact outline.
08.05.2020 13:59 # 5
Ismail
[QUOTE = sinan-s] It has nothing to do with the contact outline .. [/ QUOTE]
I agree
08.05.2020 13:59 # 6
I guess this isn't the case with immobilizer, huh? Does anyone know what happens when the immobilizer does not recognize the contact?
08.05.2020 13:59 # 7
sinan-s
[QUOTE = serk @ n] is not in a situation related to this immobilizer, I think? Does anyone know what happens when the immobilizer does not recognize the contact? [/ QUOTE]
When it doesn't recognize the key, the indicators will not work .. no movement.
08.05.2020 13:59 # 8
you will go to a clean electrician, the most beautiful and the most logical one that I will not do to you, brother,
I can't help with the problem of a vehicle I haven't seen :(
it depends on the problem of course;)
respect for the man ...
08.05.2020 13:59 # 9
Thank you, Mr. Yasar.
What are the possible causes of this malfunction. ? so what are your apparent estimates?
08.05.2020 13:59 # 10
[QUOTE = sinan-s] Welcome aboard ..
I agree with Sinan, my friend or take it to a mechanic who has this kind of machine in the industry, let's see if they can solve some of them by playing a little bit.
08.05.2020 13:59 # 11
Possible reasons
It is advisable to squeeze and clean the wd 40 that may be contactless in the contact core.
As far as I understand, you said that no electricity is coming, if the contact was not freezing and starter, I would say from the corners, but if I think there is no electricity coming from the battery, check the hood with your hand to see if there is any corrosion or contact.
Irde service in İzmir Neci İrde confirms the best sercis victorious. 1. industry Aguş master süleyman aguş. 3 industries ege lada ibrahim talda are places I can recommend
08.05.2020 13:59 # 12
when I turn the ignition, battery and oil light are on, only the engine light is not on. Pressing in the starter, switching the ignition off and on a few times, if it blows on the head then the engine is on. then the car is running.
The best sercis confirms victorious. 1. industry Aguş master süleyman aguş. 3 industries Aegean lada ibrahim talda
Are there phone numbers. I wonder
08.05.2020 13:59 # 13
BEST SERVICE
Victorious Truths
301 Sokak No: 28 Çamdibi / İZMİR
Tel: (232) 435 23 96
I bilgi@bestservis.co
Ege Lada Special Service
345 S. 6 2
Bornova, Izmir
Tel : 232 4864902 - 535 7367373
Aguş Auto Repair and Maintenance Workshop
Auto Maintenance and Repair
Izmir/
BORNOVA İZMİR
Related person : Süleyman Aguş
Address1: Bornova Izmir
Address2:
Post code :
Telephone : 232 4357574
Fax:
DERAN_TUYN is 2008-12-04 14:21:16
08.05.2020 13:59 # 14
RexxaR
this malfunction started in me too. I have been trying for a month and they couldn't solve it. Does anyone know what the cure is?
