106XS, 5th gear, 4000 revs, 130 km / h |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 14:58 | # 1 |
I have a question for the masters. I use 106XS, 97 models, 1.6 engines. I went a long way last holiday and a question like this stuck to my head. The car travels at only 130 km / h at 4000 rpm in 5th gear. It seemed abnormal to me. No problem in the hand, I went 160-170 km / h, it showed correctly. Why do you think it might be? |
| 08.05.2020 14:58 | # 2 |
In my opinion, it is normal to go for 130 km at 4000 rpm. The transmission rates of each vehicle are different. you can understand it so. For example, check the 5th gear with 2000, 3000, and 5000 rpm whichever smileys you go on. it will probably increase in proportion to the odds. As far as you can tell, your vehicle has to go 65 km in 2000 rpm. For example, my vehicle is traveling with 5th km 4000 km and 144 km. Naturally, it must be 72 km in 2000 cycles and it is exactly that face ...
| 08.05.2020 14:58 | # 3 |
Thanks for the answer. It really watches around 65 in 2000 times. On the long road, the engine makes a lot of noise, and the car is small. Someone else using 106 would also be good to inform. |
| 08.05.2020 14:58 | # 4 |
there is nothing that can be peeled anymore. The face and speed ratio in the display is normal. There is no wrong situation. You hear more engines and road noise because your car is insufficient in sound insulation. There is nothing that the general structure of the vehicle can do more than it is. If you want to do it, you can do sound isolation. If you say I will go further, you can play with the gear ratios to decrease the agility and increase the face. In this case, it allows you to obtain a speed of 130 km at a lower speed, or to make more than 130 faces at 4000 rpm ... |
| 08.05.2020 14:58 | # 5 |
Actually, I don't think of playing with the transmission. I just wondered, for the first time I went a long way with 106, the revs were lower in other vehicles I used. I think this is normal. Actually, because the speed is high, the car is more comfortable, I pass by as everyone gets down on the ramp :). You are right about sound insulation, master consultant, though I just changed the engine's chocks, the sound has decreased a lot, the wick of the left door will change or something. Thanks for advice...
| 08.05.2020 14:58 | # 6 |
hello i have xs too I bought it last week.After the message, I tried too. The 5th gear saw 140 at 4000 rpm. It may be related to the condition of the engine, but it is not a situation to be worried about. |
| 08.05.2020 14:58 | # 7 |
I'm using QS. 1,4 75HP. When you first bought it, as you said, it seemed like high speed at low speed, but I got used to it over time. The little car is after all. After 3000 cycles, the volume is increasing, there is no problem under it. By the way, I am at 160 km at 5th gear 4000 rpm. Around 130 km in 130 km. Of course, I don't know how accurate it is to compare this way. From your tire size, it also affects the slope rate on the road, including the number of people on the vehicle.
| 08.05.2020 14:58 | # 8 |
Now I'm used to my vehicle, I even get annoyed without sound I'm not shifting gears. I think this is normal, everyone says so. My dear 14 "55 thin, it can be from ...
| 08.05.2020 14:58 | # 9 |
[QUOTE = enderkesk a] hello i have xs too I bought it last week.After the message, I tried too. The 5th gear saw 140 at 4000 rpm. It may be related to the condition of the engine, but it is not a situation to be worried about. [/ QUOTE] is the gear and gear face gear motion. therefore it does not show variability. It does not change according to the condition of the engine. Even if the engine is 500 hp, it makes 140 in 4000 rpm. Due to the power difference, the time to reach that face will be very short or the torque at that face will be very different. Since the gear ratios are the same, the face ratios are the same ... |
| 08.05.2020 14:58 | # 10 |
[QUOTE = berkaygr] I am using QS. 1,4 75HP. When you first bought it, as you said, it seemed like high speed at low speed, but I got used to it over time. The little car is after all. After 3000 cycles, the volume is increasing, there is no problem under it. By the way, I am at 160 km at 5th gear 4000 rpm. Around 130 km in 130 km. Of course, I don't know how accurate it is to compare this way. From your tire size, it also affects the slope rate on the road, including the number of people on the vehicle. [/ QUOTE] I think you have friends with wrong information, let me know. Let's write something similar to you, similar to what I wrote in the other friend's comment. The gear and the face of the vehicle do not change according to anything. As you said, it does not change according to the elevation of the road. does this gear move show this change ??? you say rubber cap, it just changes your real face. If you change the cap of the tire, the indicator shows what it knows. Because the smiley indicator reads the number of rotations in the transmission. it does not know that the tire cap has been replaced. If you have worn a 5% bigger tire, you will be ticking 105 while typing 100 in the display. or vice versa. Let's say a general presentation. these turnover rates vary from transmission to transmission. ultimately it is the engine that turns, but the gears that are turned. For example, the gear ratios of the 1.4 engine and 1.6 engine may or may not be the same. this depends on the manufacturing situation of the factory. but everything must be the same on the same vehicles. Whether the engine is hanging or not ... |
| 08.05.2020 14:58 | # 11 |
Well, for example, does not the speed increase to keep the vehicle at the same speed when I come to the ramp while driving on the straight road with 50km in 2nd gear?
| 08.05.2020 14:58 | # 12 |
Carmania |
What I know is the 2nd Gear 6,500 rpm 100 km, I remember with the gti wheels, the 5th gear is 110 km at 3000 rpm.
| 08.05.2020 14:58 | # 13 |
[QUOTE = berkaygr] Well, for example, does not the speed increase to keep the vehicle at the same speed when I come to the ramp when driving on the straight road with 50km in 2nd gear? [/ QUOTE] no it does not rise. If something had happened that way, the clutter would be running away. I wonder if you are talking about the automatic gear ??? the clutch is variable from cycle to cycle depending on the pressure on the accelerator pedal.
| 08.05.2020 14:58 | # 14 |
[QUOTE = Carmania] I know 2nd Gear 6.500 rpm enters 100 km cutter with gti wheels, 5th gear at 3000 rpm I remember 110 km .. [/ QUOTE] This is true in your vehicle. but not every vehicle may be equivalent. the values you are saying are the same as mine. I get 100 to 6500 reds in the 2nd line The 5th line is 72 in 2000 cycles, 108 in 3000 cycles, 216 in 6000 cycles ...
| 08.05.2020 14:58 | # 15 |
Carmania |
It may not be the same as yours. Cecoli brother will have a difference in seconds. There is a difference in weight. |
| 08.05.2020 14:58 | # 16 |
[QUOTE = Carmania] It may not be the same as yours. Cecoli brother will have a difference in seconds. There is a difference in weight. [/ QUOTE] You are right, I forgot that mine is the car of kagn :)))
| 08.05.2020 14:58 | # 17 |
Carmania |
Estafurullah I did not mean to die, you misunderstood
| 08.05.2020 14:58 | # 18 |
yahu, I told his jokes :))) I put my smile behind him, didn't you see ??? look I put it again :))) Of course there will be differences in acceleration. In short, the acceleration difference ...
| 08.05.2020 14:58 | # 19 |
Carmania |
I understand, good health, cecoli brother is not a problem, only I do not like to break the heart breaking the environment so it was like a misunderstanding because I came to my car. we'll go :) |
| 08.05.2020 14:58 | # 20 |
Let us see young people, such as young people, on the piasters. These are the movements that smell ad: DDD let's not worry about you aside me :)) I think you had 106 gti? |
