1.0 vti blowing white smoke
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
12.07.2020 19:00 # 1
TeamMcLaren
Hello guys, I have a 2013 model 208 at 94 thousand km. When I started the car yesterday, it suddenly became white. While driving the vehicle, it gives off a lot of white smoke as it gives off gas. I felt excessive jerking at idle, a jingling noise from the bottom when accelerating and clutching the clutch, I also felt power loss in the engine. The heat was normal along the way, I did not see a drop in the coolant / mixing of oil with water. A few months ago the catalytic converter had failed but I did not do it. It has also been reducing 1 liter of oil per 1000 km since I bought it. However, I have never had a smoke throwing complaint until now. What do you think could be the reason? If the catalytic converter is completely clogged could it cause such white smoke?
13.07.2020 01:08 # 2
GokhaN
I have not heard that the gasoline vehicle emits white smoke from the catalyst, but the vehicle is probably burning oil
13.07.2020 12:25 # 3
What is the viscosity of the oil you put in your vehicle, teacher? It is not normal to decrease 1 liter of oil by 1000 km. Have a compression test. In addition, I have never changed the coil and spark plugs between you.
13.07.2020 18:23 # 4
TeamMcLaren
[QUOTE = sonerkyl] What is the oil viscosity you put in your vehicle, teacher. It is not normal to decrease 1 liter of oil by 1000 km. Have a compression test. In addition, I have never changed the coil and spark plugs between you. [/ QUOTE] 10w40 teacher. Spark plug changed in 89 thousand. Coil not changed
