10 THOUSAND MAINTENANCE PUG 206 SEDAN
08.05.2020 19:44 # 1
OguzhanKucuk61
With an acquaintance recommendation, I went to an unauthorized Peugeot shop to have 10 thousand maintenance. I explained the situation and it costed 150 liras including 65 lira oil, 20 lira oil filter, 20 lira air filter, 20 lira pollen filter and 25 lira workmanship and the price did not come very high. As I haven't researched before, it is probably normal that I was ready for these prices because of 150-200 hearsay. Master gearbox and oil filter replacement is not necessary, said the master. I said ok they did. The counter has been reset and is ready to count 20 thousand km on the display. They said something like that, I heard 10 thousand and something like that. I said let me see the prices when I come home and think of me. I saw that the price of the "total Elf 10w40 sporti" they used was sold for 35-40 liras of the 4-liter oil and I was a little uneasy. Wunder brand filters were installed. I couldn't find the price information of the filters. What do you think is this situation? Are the prices normal? The interval of maintenance should be done every 20 thousand according to the meter of the car and the master says every 10 thousand? Shouldn't the transmission oil and petrol filter really change? My first vehicle and my first 10 thousand :) thanks
08.05.2020 19:44 # 2
samet206
Obviously, masters do not want to change the gasoline filter very much. I do not see it as something that should change as often as the air filter. If you have a complaint, it can be changed from the gearbox and if it can be resolved by changing the oil, then it can be changed in the name of maintenance. we do the same amounts, there is not much to do about it. Maintenance event 10w40 oil change time 10 thousand km, 5w40 oil change time 15 thousand km change time such a situation made me explain about the service oil, call If you follow this material according to the material used, not the three meters, this period is better. If you cannot do 10 thousand within 1 year, it is beneficial to have a yearly oil maintenance. You do not need to wait for 10 thousand km.
08.05.2020 19:44 # 3
OguzhanKucuk61
Thank you very much for the explanation, Samet, it means that the master did not have any grumpy sides :) thank you very much :)
08.05.2020 19:44 # 4
seamad
I had maintenance yesterday, mobile super 5/30 oil 65 TL, air, pollen, oil and diesel filter 107 TL products were bought from the original peugeot authorized service, the normal price is much higher but my special discount :) 172 TL material 20 TL, labor at 192 TL vehicle 2006 peugeot 206 1.4 hdi 161.000 km, after the maintenance of the vehicle, it was as if it came out of the winter and dressed in summer shoes :) Meanwhile, I do maintenance every 8-10.000 km diesel filter changed at 33.000 km.
08.05.2020 19:44 # 5
OguzhanKucuk61
Thanks for the information Seamad teacher :)
08.05.2020 19:44 # 6
Ahmetaltan
[QUOTE = seamad] I had maintenance yesterday, mobile super 5/30 oil 65 TL, air, pollen, oil and diesel filter 107 TL products were taken from the original peugeot authorized service much higher than normal price but my special discount :) 172 TL material Workmanship at 20 TL, 192 TL vehicle 2006 peugeot 206 1.4 hdi 161.000 km, after the maintenance of the vehicle, it was as if it came out of winter and dressed in summer shoes :) Meanwhile, I do maintenance every 8-10.000 km range, I changed the diesel filter at 33.000 km.
I will have my car serviced soon, now the oil I use is mobil 10/40. My friend Seamad wrote that you used 5 / 30w oil in which direction you made this preference. I was thinking to replace it with 5/40 w full synthetic oil. Thanks...
08.05.2020 19:44 # 7
seamad
[QUOTE = Ahmetaltan] [QUOTE = seamad] I had maintenance yesterday, mobile super 5/30 oil 65 TL, air, pollen, oil and diesel filter 107 TL products were bought from the original peugeot authorized service much higher than normal price but I have a special discount :) 172 TL material, 20 TL labor, 192 TL vehicle 2006 peugeot 206 1.4 hdi 161.000 km, after the maintenance of the vehicle, it was like getting out of winter and wearing summer shoes :) Meanwhile, I do maintenance every 8-10.000 km range. I change it.
I will have my car serviced soon, now the oil I use is mobil 10/40. My friend Seamad wrote that you used 5 / 30w oil in which direction you made this preference. I was thinking to replace it with 5/40 w full synthetic oil. Thanks ... [/ QUOTE]
Since I bought the car, I have been using 5/30, it says that I use 5/30 in the masters I went to, look now we are suspecting that we are putting the acep wrong oil now.
08.05.2020 19:44 # 8
seamad
Looked out from Castrol suggests 5 / 30w for our vehicles (1.4 hdi)
08.05.2020 19:44 # 9
Ahmetaltan
[QUOTE = seamad] I looked from Castrol suggests 5 / 30w for our vehicles (1.4 hdi)
It says 0 40w or 5 40w on its mobile site. I'm confused now. :)
08.05.2020 19:44 # 10
Gokcesel
I did the maintenance of the vehicle yesterday. I bought the products from Hakan Peugeot in Ivedik. The list is as follows;
Totaz Quartz 7000 10w40 oil: 50TL
Diesel pump: 50TL
Air filter: 15TL
Pollen filter: 15TL
Oil filter: 10TL
+ I also changed the crankshaft pulley of my vehicle and gave him 150 lira. I gave 100 lira for workmanship and went up to 390 in total.
