1. gear resistance?
08.05.2020 20:52 # 1
pejoucyuzsekiz
Hello friends, you know, while the vehicle is moving slightly, it is difficult to shift to 1st gear. I have 1-2 questions about this.
1. What is the system that causes this strain?
2. The car has slowed down quite a bit on the second ramp in the second gear.
thanks.
08.05.2020 20:52 # 2
First of all, welcome to us.
1-My teacher about this gear structure. 1 gear is used to move the vehicle. When I reach a speed of 10-15 km, I usually put 2 gear. It is difficult to shift from 2 to 1 gear at speeds of 10-15 km. It usually passes near stop or under 10 km.
2-I don't think it did any harm, but if you use it constantly, it will harm.
08.05.2020 20:52 # 3
pejoucyuzsekiz
[QUOTE = sonerkyl] first of all welcome to us.
thank you .. the sound that I heard was worrying was my speed was actually low ..
08.05.2020 20:52 # 4
Occasionally, sometimes it happens in me. As I said, there is no problem. Be sure in many brands. it does not shift to 1 gear when it does not fall below a certain speed. or you have to force it like that. There are videos on youtube, for example, there was a shaker, when you were going with 120, you shifted into 2 gear.
08.05.2020 20:52 # 5
boruc
There is usually this situation already
But after the axles were inserted and installed in my vehicle, it started to have a harder night.
It freezes to normal when it gets hot.
Why could it be? Did they put oil missing? Or is it the type of oil put in different?
08.05.2020 20:52 # 6
samet206
I have experienced this situation, even if this event does not harm anything, it may cause the gear stick to be damaged, if it becomes continuous. In situations, the 1st gear increased the tolerance, it was better when the original on the gear stick and I remember that I continued to be satisfied for a long time after these operations. As it is, only some vehicles do not feel more comfortable in this situation, but some are more.
