1.9 d partner fuel recommendation
08.05.2020 15:52 # 1
theextrame
Hi guys first
I have a 2005 partner 1.9 d
on average I change gear at 3000 rpm
In the 5th gear, I usually drive at 3200 rpm at 110-120km / h.
I constantly buy full oil euro diesel on my vehicle and try not to drop it under half tank
Finally, I use my vehicle without load in Istanbul for specific purposes.
my question is like a partner with yours
it seems to me that this vehicle burns a bit Smile
Based on the information I provided, I would suggest you not to go over the top speed, for the least fuel, for example: How many revolutions in the 5th gear?
last month i made istanbul-tekirdağ, tekirdağ-istanbul
On the way to Tekirdag (where the exit takes place), I bought 80 TL of FULL petrol euro diesel (when it was in the bottom of the quarter), I went to the center of Tekirdağ via a 70-80 km / h speed from Silivri. ranges between 3600-4200 rpm.) I bought a lamp of 70 TL from the PO in order not to risk the lamp lit up at the first PO. Confused
but there is a situation like this
I traveled on ist-t.dağ road in a range of 70-80 km / h in a silivriye
I came directly to Istanbul without stopping between 130-150 km / h on t.dağ-ist road
As far as I know, the car that goes at a constant speed burns less and I have the opposite. Smile
I will say that next month I will go to my hometown with my family (1200 km without stopping except 2 or 3 breaks) to me with this 2005 model 1.9 d engine (5 people from an average of 80 kilos). I have to watch at d / d
thanks in advance
08.05.2020 15:52 # 2
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading of "Getting to Know Our Members ". Filling in all the information will help us to get to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 15:52 # 3
Euro diesel is not used in 1.9 d engines, it burns very much. You will use normal diesel.
08.05.2020 15:52 # 4
theextrame
I understand, but there is no more diesel in the market anymore, something is still sold under the name of diesel yes but the euro does not perform as much as diesel, so it does not burn much :)
The reason I explained that much detail above is to understand how to use my vehicle.
For example, I am going to go to conquest (ist-mugla 826 km) with my car in Ramadan feast.
Whatever speed and cycle I go, I go by learning how to calculate and burn with a quick burn
that is, how many km of speed and rpm should I not exceed at the highest speed for the least fuel?
08.05.2020 15:52 # 5
vbmaster
I do not know what the masters say for optimum, which should not exceed 3200 between 90/100 ...
08.05.2020 15:52 # 6
Faruk
If you go around 2000 rpm then the vehicle will burn less, it will point out around 90 in those rpm.
08.05.2020 15:52 # 7
theextrame
[QUOTE = vbmaster] I do not exceed 3200 between 90/100 but I don't know what the masters say for optimum ... [/ QUOTE]
this vehicle speeds 115-118 km / h at 5th gear 3200 rpm.
[QUOTE = Faruk] If you go around 2000 revolutions then the vehicle will burn less, it will mark around 90 at these revolutions. [/ QUOTE]
this vehicle has 2000 revolutions with 1.9 flat engines, means 85-90 km / h speed and also the gearbox has a forced cycle due to the lower gear range.
friends, I say mugla, I say 830 km, if I go with 100 km / h, it will take 8.5 hours from the head and add it to the traffic. Sırıtma How many hours will I get there
I have been doing research on the net, but serious speed / fuel research for this vehicle is either not done or not shared Shocked
I am waiting for the sharing of friends who have experience in this matter.
08.05.2020 15:52 # 8
metin
You want to go quickly and you want less. If you want it to burn less, you will risk going late.
the 5th gear burns at least at 2500 rpm in gasoline vehicles,
In diesel vehicles, the 5th gear burns less than 1750-2250 rpm.
08.05.2020 15:52 # 9
Faruk
you are telling the truth, the road will not burn with 90, I do not cut, I go at 110-120 speed, without going up and go into the radar, it does not even cut, when it goes to 90 with the road computer, it drops to around 4-4.5 or even 3.2, but when it reaches 120 5 5-r goes up to 6 mercury , even sees 7. There is nothing to do for him.
08.05.2020 15:52 # 10
theextrame
[QUOTE = text]
This is what I was trying to learn, I wish you could directly help without reacting Ouch
08.05.2020 15:52 # 11
theextrame
[QUOTE = Faruk] you are telling the truth, there is no way to go with 90 to make it burn, I do not cut even at 110-120 speed, before going up and going to the radar [/ QUOTE]
it is a shame to ask the radar how to get to the radar, it will be a long way until 90-90 :))
08.05.2020 15:52 # 12
metin
[QUOTE = theextrame] [QUOTE = text]
Don't react to misunderstanding, let me go fast, I want to burn less, but unfortunately, it does not happen.
08.05.2020 15:52 # 13
metin
[QUOTE = theextrame] [QUOTE = Faruk] is not going to be taken with 90 because it is a little burn, I am traveling at 110-120 speed, without going up and getting into the radar even it does not cut [/ QUOTE]
According to the new application, the speed limit is 110 on divided roads. Since there is a tolerance of 10%, if you exceed the speed of 121 km, you will be punished by radar. But since your vehicle enters the van, it should be 90 speed limit.
