1.6 VTi master
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 21:28 # 1
adige_janbora
hello friends I have a 2010 model Peugeot 3008 VTi engine.
Burning fat
ABS + ESP + handbrake fault light
And the vehicle gives exhaust emission failure.
Is there a master on the European side of Istanbul who knows the competent person from this engine?
08.05.2020 21:28 # 2
ismailkaya
I think take it to your authorized service. Kagithane 4.levent sultanselim cad. Failure detection and price quotation at the entrance to get somewhere immediately
08.05.2020 21:28 # 3
First of all, welcome to us. Sir, due to the structure of the VTI engines, oil depletion can be seen around 10000 km and 2 liters. This is not a problem. The oil quality used is important. Which brand of oil do you use in your vehicle? Especially in cyclic uses, this oil reduction can be seen even more. In my 308 vehicle, I used motul 5w / 30 fe. In the first change, the reduction was 5000 km and 1.5 liters. In the subsequent changes, this consumption decreased to 5000 km and 500 ml. This is because most of the new generation vehicles with eccentricity have this reduction. The reason for the abs + esp malfunction is a common situation in the minus cases, because of the oxidation in the abs sockets and inside the cables. Of course, I recommend you to have your vehicle checked by an original diagnostic device. You can find out the state of the engine by performing a compression test. They test between 50-100 rubles.
