1.6 hdi white smoke?
08.05.2020 21:11 # 1
Fikox48
Hello. I had opened a subject before, but the problem persists. The vehicle starts jerky at the first start and emits white smoke. The injectors were inspected twice, with the engine also directed to the iron. In the first process, it is said that there are minor imperfections and the process is completed, but the problem continued. In the second one, the return value was high in an injector. The master fitted the problematic nozzle into another injector and the values returned to normal. Let me change the nipple, despite my insistence, he talked about the fact that this could happen, the values were normal. As a result, the problem continues. There is no oil reduction in the vehicle. No performance loss, no high fuel consumption. The vehicle is in the authorized service right now and the injector could not find any problem. Strangely enough, this problem doesn't sometimes happen, the vehicle runs smokeless. Finally, the car has a spark plug malfunction, but the general opinion of the users is not to cause it. I'm waiting for your help.
08.05.2020 21:11 # 2
I think it is absurd for them to change if the glow plug is failing, but sometimes it can break when the cause is removed, it tries to be removed by the spark plugs and the screwdriver, or the top cover may need to be removed because they may miss parts in the engine, so they do not want to approach. I also remembered the possibility of turbo on some foreign forums, if I don't remember wrong.
08.05.2020 21:11 # 3
Fikox48
It takes up to two minutes. So he does it when it's cold.
08.05.2020 21:11 # 4
Fikox48
08.05.2020 21:11 # 5
Also, did you change the fuel of my teacher, have you tried any other stations? In addition, use a little bit of compression on the ring road, 10-15 minutes at low gear, high speed .3500-4000 dd will be sufficient.
08.05.2020 21:11 # 6
Fikox48
I did what you said, but there was no solution. The authorized service stated that there is also a problem in the future. Could it be caused by Egr?
08.05.2020 21:11 # 7
If egr is also a problem, it usually throws black smoke. I guess there is only one piece that you haven't changed since it's full
08.05.2020 21:11 # 8
pusutr
Have you checked the turbo hoses that will be a little classic?
Also, I think change the station you are refueling.
I think your problem is in one of these.
08.05.2020 21:11 # 9
Fikox48
I will check the hoses. But I don't think it's a problem. Because this problem happens when the engine is cold.
08.05.2020 21:11 # 10
Fikox48
A master on the recommendation said that the cause of the white smoke is the injector or the cylinder head gasket. What are the symptoms of this second condition I wonder?
08.05.2020 21:11 # 11
baran sel
brother and sister have the same problem in my vehicle.
08.05.2020 21:11 # 12
ismailkaya
Look at turbon and piston circlip liners. the piston may be melted, the turbon may be leaking oil to the engine
08.05.2020 21:11 # 13
baran sel
the master throws the oil in the turbo. He said that especially the long journey, the turbo should open itself. but there is nothing to do on such a long road right now
