1.6 HDI 407 chip application +30 HP
08.05.2020 15:34 # 1
MaximuS
friends, I made chip application on the engine of my vehicle, where I almost finished external modification applications. With the advice of the master, who I totally trust in every job, the number 10 workmanship and performance came out ...
CONCLUSION: A 407 that does not stand in place and stacks at high revolutions, collecting horseshoes for all of its peers (D class 1.6 vehicles).
08.05.2020 15:34 # 2
Your Eye Aydın Abicim You Broke 30 Horsepower So Under The Hood Sırıtma
08.05.2020 15:34 # 3
voodoo
good luck..but how did you get 30 hp plus can you explain in us ... what changes were made in your vehicle ??
08.05.2020 15:34 # 4
Engin Tepe
30 hp can be harmful to the jeep directly.
08.05.2020 15:34 # 5
metin
[QUOTE = MaximuS] friends I applied chip application to the engine of my vehicle, where I almost finished external modification applications. With the advice of the master, who I totally trust in every job, the number 10 workmanship and performance came out ...
CONCLUSION: a 407 ... [/ QUOTE] that does not stand in place and stacks at high revs for all horses (vehicles of class D 1.6).
How did you calculate 30 hp? Did you test dyno too?
I also trusted the master until the day when he changed 2 Z rods to 100 TL.
08.05.2020 15:34 # 6
mdincer34
I wish he could carry a horse in our vehicle :)
08.05.2020 15:34 # 7
I wish you good luck using it. What is the cost of installing this software heat ???
08.05.2020 15:34 # 8
good luck
08.05.2020 15:34 # 9
MaximuS
friends return to questions:
chip application only. There is not much else I know for HDI.
I did not take the dyno test, I just give numbers according to the data of the device.
adds 25% power to the standard stock. which corresponds to 27.5 HP, according to 110HP, or approximately + 30HP.
08.05.2020 15:34 # 10
In fact, this software is able to increase power up to 35% in the diesel. But the boundaries may be straining ...
08.05.2020 15:34 # 11
MaximuS
thank you for your good wishes. The cost is around 400 TL for friends.
about 6 months ago I had consulted this master. At that time he had told me that there is no product to be trusted in the market, I should not hurry. As I passed by, I was wearing 1.4 D4D corolla when I went. I said no, dude, you didn't recommend that much? He said a guaranteed product, and I also vouch for and guarantee. he said, if you have a problem, i will take your expense
By the way, my friend who does not trust the master of harun, I do not know what happened between you, but my law is different with the master of harun. there may be a misunderstanding. I never thought I could find such trades in Istanbul. There has been a lot of work, if you are not satisfied we will dismiss it, we will not take anything ...
08.05.2020 15:34 # 12
Best wishes. 30 HP nice plus.
08.05.2020 15:34 # 13
MustyRC
best wishes. I hope it won't cause any trouble in the future, after all, 30 hp is not a small figure.
08.05.2020 15:34 # 14
Haksen016
I'm sure the tool has been another. best wishes.
08.05.2020 15:34 # 15
For a minute, I understood the essence of the event. The application you have made is not "Chıp Tuning".
Have you installed a "Power Box" inserted between the connector of the injector pump .........
It has a small plastic box and 2 sockets. You insert the socket of the injector pump and connect it together and give the injection pump different scrubs, increasing the pull of the vehicle ...
When I said he was wearing it, I understood because chıp tuning is the new software to the vehicle's medicine. Depending on the location, the computer connects to the vehicle ecu via the OBD2 socket, or the ecu is removed, the chip is inserted on the top, and the new software is installed again, etc. ...
the cecol 2011-06-09 08:43:39
08.05.2020 15:34 # 16
Normally, the power of our vehicles is stronger than the data given to us by the factory, but because of the European criteria, they reduce the power of our vehicles with computer software because of the European criteria. however, this shows itself in the form of spending too much fuel.
08.05.2020 15:34 # 17
[QUOTE = Bahadır32] Friends are normally stronger than the power of our vehicles than the data given to us by the factory, but due to the European criteria, manufacturers reduce the power of our vehicles with computer software than they should. the engine of the vehicle gets its real power, but this is manifested as a waste of fuel. [/ QUOTE]
Some of them are peeling the dust of the fuel. What will you call it ??? Sırıtma
They claim that 5-10% of fuel can fall, as the engine is stronger, making the case move more comfortably.
But at this point, exhaust emission CO2 emission is increasing, I guess ...
08.05.2020 15:34 # 18
metin
[QUOTE = MaximuS] thank you for your good wishes. The cost is around 400 TL for friends.
I was also confident in it, I was traveling 30 km without getting cold, when I went to the service for the last transmission, it was upsetting that the harun master installed the crank pulley as the original industry and bought the original money and the service changed the original Z rods to 70 TL while the harun master changed the sub-industry z rods to 100 TL. I do not even count the request of 120 TL when I call the speed stabilizer that I have installed for 30 TL.
08.05.2020 15:34 # 19
[QUOTE = text] [QUOTE = MaximuS] thank you for your good wishes. The cost is around 400 TL for friends.
Apparently, this master is treating his man according to his ... I believe that there was no correct behavior.
08.05.2020 15:34 # 20
[QUOTE = CeCoLi] [QUOTE = Bahadır32] Friends are normally stronger than the power of our vehicles with the data provided by the factory, but because of the European criteria, manufacturers reduce the power of our vehicles with computer software than they should. With chiptuning or similar applications, the engine of the vehicle gets its real power, but this manifests itself in the form of spending too much fuel. [/ QUOTE]
They say it is, but it's not performance = plus fuel. Gülme I do not know its accuracy, but if it really helps to reduce fuel consumption for a long time, it means it is useful.
Page : / 3
