1.6 gas temperature problem
08.05.2020 21:02 # 1
lilokan
Friends, my vehicle does not fall between 100-110, both in the city and on the long road. The thermostat has changed. I wonder if the master said the owner of the radiator?
08.05.2020 21:02 # 2
Anyway in the city, my teacher may have a radiator that should fall 90 on the long road. Another possibility may be the circulation pump. It is also necessary to control the fan relays and fan resistance of the vehicle.
08.05.2020 21:02 # 3
lilokan
My teacher doesn't open where the fan should. Bakiom overheat at 100 I look down and the fan is not open. Sometimes I look under 100 fan is open?
08.05.2020 21:02 # 4
then have my teacher check the fan roles and the fan resistance. oxidation in these parts, etc. If this happens, you may encounter this problem.
08.05.2020 21:02 # 5
Burak3405
https://youtu.be/iEifp508bqw ; Does anyone have an idea for a solution proposal?
08.05.2020 21:02 # 6
[QUOTE = Burak3405] https://youtu.be/iEifp508bqw ; Do you have any idea for solution proposal friends [/ QUOTE]
First of all, welcome to us. The link is not open, if you have the opportunity to renew my teacher again, let's try to help.
