1.6 106 XR Acceleration Problem
08.05.2020 19:20 # 1
Thegodable
Hello
I bought the 1.6 106 XR vehicle just 211 thousand km. My problem is that he's doing max 130. The ramp does not exceed 60. I replaced the air filter, the oil is in good condition. This may be caused by the problem. I haven't had gas adjustment yet, but the gas has the same problem. Shouldn't this vehicle be a monster?
I request your help on the subject.
08.05.2020 19:20 # 2
Firstly, look at the spark plug and cables - ignition system, the coil may be faulty.
08.05.2020 19:20 # 3
outlaw
1.6 IS NOT XR
XR IS NOT 1.6
1.6 XS SINGLE DOORS, 4 DOORS
1.4 XR 4 DOORS ONLY
WHEN IT IS PROBLED, THERE IS NO MORE ABOUT 1.4
BUT 1.6 IF IT IS TROUBLE
PERIODIC SUMMER CARE MAKE THE CATALIZER IN THE SERVICE, EVEN HARD THE CAR ...
08.05.2020 19:20 # 4
Thegodable
It says 1.6 XR on the license, what's what then
08.05.2020 19:20 # 5
ertanb
Well, I have 1.4 xr, no gas, no ramp, no fainting, and when I was 4 people, I saw 160 on the highway in the car.
08.05.2020 19:20 # 6
ertanb
My advice to you is to look at axles and pressure on honey.
08.05.2020 19:20 # 7
Thegodable
If there is a problem in the axles or pad and if we do not (for financial reasons), can it cause any danger? In terms of damaging the vehicle?
08.05.2020 19:20 # 8
ertanb
If you cut an axle or if the pressure runs out, cutting the road may cause trouble.
08.05.2020 19:20 # 9
Thegodable
The engine does not have difficulty, the vehicle goes on a role. I am worried that the engine must enter the competition. How can I do the engine test with driving?
08.05.2020 19:20 # 10
ertanb
Teacher, they raise the oil cover and see if they pull the cover, if they do, they say the engine is good. He called it a ole to me but I don't know how accurate it is. Your problem may be in the ignition system.
08.05.2020 19:20 # 11
Sertac
Sibob setting;)
08.05.2020 19:20 # 12
samet206
First, good luck. Now I agree with the XR 1.4 engine, I don't know if there is no 1.6 XR. I also did not come across. Also, there is a problem in 211 thousand km, 97 model gas vehicle does not need to be like a monster. they may have played with the gas setting to be slow, the pressure is depleted on the pad, there is a problem in the ignition system or the axes can cause problems such as knocking, flickering, accumulation in the axles.
08.05.2020 19:20 # 13
Thegodable
Hello, Thank you for your valuable comments.
Happy ramadan.....
08.05.2020 19:20 # 14
ertanb
Teacher, whatever the problem is, I would appreciate it if you share it with me.
08.05.2020 19:20 # 15
Thegodable
Of course I share, but I couldn't make it to the vehicle yet. I need money in my hand ..
08.05.2020 19:20 # 16
Sertac
Hodja, I had the same problem in me. I even opened a subject. The sibob setting of our vehicles is different. First, go to a beautiful Peugeot master. Look at the audio setting. Then make the sibob setting. I made the setting for the sibob, the car became a plane than before :)
08.05.2020 19:20 # 17
Thegodable
Could I have thought that the valve is already hitting it, the sound is coming. So, do you know that there is a nice Peugeot master Kartal Pendik? And how much does this valve setting cost, master?
08.05.2020 19:20 # 18
Thegodable
[QUOTE = Thegodable] Could I have thought that the valve is already hitting it, the sound is coming. So, do you know that there is a nice Peugeot master Kartal Pendik? And how much does this valve setting cost, master? [/ QUOTE]
Isn't there anyone who can help with this?
08.05.2020 19:20 # 19
serdaralisan
MY FRIEND THEY X 1.4 through sales in the Notaries OR TRAFFIC BAD WRITING SOUCI VEHICLE 1.6 ENGINE LOOKS CHASSIS NOTE who question the BI PEJO particles from MY 1.4 EMERGED was EVEN ENGINE ON I PISTON DIAMETER FLIR 1.4 THAT ARISE had BAY BENDER WHY MORE TAXES I GIVE I SAID I WENT TO TRAFFIC TO FIX They THEY DÜZELTMEYİN by BEN VEHICLE ENGINE 1.6 DO TROUBLES NOT SO ACCORDING tO 1.6 WRITES they ALWAYS HEAD in LICENSES iN MY CURRENT VEHICLE my FIRST I HAVE 5 HAND CHANGE you SORA YELLOW tO RETURN RECEIVED tHE oRIGINAL was BLACK PEJO 106 SX1 1.6 8 VALVE VEHICLE BACK ALDIM VEHICLE OTHER LICENSE PDP in the SX1 are STUCK BY OTHERS in XSI SAYS HEAD Neymiş in Turkey in tHEIR SYSTEM THE SX1 IS THE MOST NEAREST BRANDS OF THOSE WHO HAVE DONE
08.05.2020 19:20 # 20
serdaralisan
make friends valve adjustment with 30 cents, if it is gasoline, it should be made with 25 cents, since the vehicle with lpg will be suitable for 30 cents for working at higher temperatures and if injected the vehicle is injected, clean injectors, clean the throttle, look at the oxygen sensor, the vehicle will cry even if the car is blocked. But if you do not go, the valve setting, the valve setting, at most 50 TL, if you have the lowest familiar master, of course 20 TL, the vehicle will not work very sultry, or if the valve does not come at all, it is called a tight valve. This causes late work at the first starter. When the balls spin the steering wheel turn left and right, if there is a clattering sound, look at the flows, while the ball is moving forward, it constantly makes a clattering sound. The sound of the ball is jammed. You change the balls of the hubs. It is 300 tl with total workmanship. The most expensive one also tightens the brake pads. I often encounter this. Run this vehicle for 2 km. Go to the brakes. If you were in Bursa, I would look at your vehicle.
Page : / 2
