1.4 xr fuel consumption
08.05.2020 15:04 # 1
%106
friends, what is the average fuel consumption of my 1,4 xr 106 automatic transmission gasoline
I just bought the vehicle, but the consumption was too high, I traveled 200 km to 100 liras, is that normal?
08.05.2020 15:04 # 2
sedatdatse
HELLO MY FRIEND HAVE 206 SI
YOUR WINTER WILL MAKE MOST 100 TL OR 240 KM WAY FALAN
THE ROOM IF YOU DO WHAT I WRITE
AIR FILTER
PETROL FILTER
OIL FILTER + OIL
SPARK PLUGS FRENCH DOUBLE NAIL
WHEELS MAKE IT LARGE
Even if the exhaust is empty, it throws a lot of raw
IT MAKES IT DIFFERENT IN USING MORE THAN SPEED
FRIEND I MADE ALL OF THIS WHAT I WRITE IN WINTER CONDITIONS, I AM IN SHORT DISTANCES
I WANT A LOT OF 100 TL OR 260 KM FALAN BUT THE LONG WAY IS CHANGING
08.05.2020 15:04 # 3
%106
thanks
i bought this vehicle about a month ago
oil, I did not change the oil filter or something
I just installed an air filter
Maybe a little because of that, but I think it doesn't matter that much.
08.05.2020 15:04 # 4
sedatdatse
actually the air filter saves fuel, but when you press the gas because its sound is nice
of course, there is no savings in pejo gas as it passes,
08.05.2020 15:04 # 5
%106
Well, we said we had some sound, but I didn't get much sound because the car was automatic.
08.05.2020 15:04 # 6
Muhammet CAKIR
if you exhaust automatically, but you get the sound
08.05.2020 15:04 # 7
%106
exhaust screams too
it won't be good if it catches in traffic
I want to get some sweet voice
08.05.2020 15:04 # 8
scuderia
Between petrol and kastamonu ankara, I traveled with 58 TL gasoline 206 1.4cc 250 km ...
08.05.2020 15:04 # 9
dbmaster
the gasoline car is finished in turkey, thanks to the state, it is only my irresponsible government that makes this fuel.
diesel vehicle IN
petrol vehicle OUT
08.05.2020 15:04 # 10
Sedat Yildirim
Selamun aleykum.
I also bought a new 2002 automatic 206 XR gasoline.
My car burns output up to 63 cents last.
I always researched from the net, it burns less than I do.
I went to the exhauster, the muffler was broken, I said.
I went to two separate services, it drops up to 50 Kurus at most,
They said not to be wasted, so I could bring it down.
The spark plugs are original and the air filter is new, however
He was burning 63 cents in the city.
The road you go is 7.5 Km. You start the star, before the engine is 90 degrees
"You're going to be running out of the road and you are cramming."
Well, I said so, and friends, when I was the left lane road user,
I stepped on my throat and as a friend said on this site,
I went to work as if there was an egg under the gas pedal.
I have always used the right of the road. Engine as much as possible 2000
I tried to keep it in cycle.
I'll be late, so I'm going to work already early, so what do I do in a hurry?
I applied this.
1-Exhaust changed.
I tried not to exceed 2-2000 cycles.
3 - Again, I followed the advice of a friend on this site and
I didn't follow the vehicle closely so that every time I brake it, I
In order not to do so, by not using the brake too much, you can
I did not increase and thus reduced the vehicle to 36 cents per km in the city.
So if I use it even more calm, it will definitely drop to 35 cents.
Thanks to going for 70-75 km with 50 TL gasoline, now it has gone 135 kilometers.
So driving techniques are very important.
With greetings and prayers.
08.05.2020 15:04 # 11
CaLL
I burn 75 krs at km 97 model 106 xr manual gear 1.4 engine direct output from the manifold sound is very nice but fuel is bad f
08.05.2020 15:04 # 12
34sea45
I have 98 1,4 xr chip brain open air filter silencer 100 TL I make 350 km
