1.4 XR 307 Cycle and Oil Pressure Failure
08.05.2020 21:28 # 1
pluviofil
Friends greet everyone,
2005 Model 1.4 Gasoline LPG Li 307 vehicle. My vehicle is running smoothly while driving, but to stop or when I slow down, the trip computer gives oil pressure error, the oil lamp and the Stop lamp flash for a short time, I change the oil filter and oil all the time, also my vehicle does this only when the engine is warming up, however my vehicle is running at idle it constantly fluctuates, but there is not a lot of stopping. When my vehicle is running at idle, when I do some movements such as opening the air conditioner opening windows, lowering the lifting steering wheel, it starts to fluctuate again and the cycle is over 1000. I changed the oxygen sensors and catalyst, cleaned the throttle several times and adapted it, however, we tried it with different gas butterflies, the error did not improve.
Do you have an idea or have you ever met anything like this before?
Note: When using gasoline, the car does not make these mistakes much, but if you notice petrol lpg now, these errors are present.
08.05.2020 21:28 # 2
ismailkaya
Tolga If you are from Ankara, there is a person who will solve your problem in Ankara.
08.05.2020 21:28 # 3
pluviofil
[QUOTE = ismailkaya] Tolga If you are from Ankara, there is a person who will solve your problem If you find that friend in Ankara, he will solve your job [/ QUOTE]
Yes I work in Ankara who can solve
08.05.2020 21:28 # 4
First of all, welcome to us. We can say that 1.4 90 hp is a chronic problem. As you say, it is usually with a throttle. You have done many things to do. Did you change the vehicle's oil sensor. There may be a problem with electrical wiring or sockets. If you are in Ankara, there is a Mas Peugeot and if you want, show them there, both electricians and mechanics are good.
08.05.2020 21:28 # 5
pluviofil
[QUOTE = sonerkyl] first of all welcome to us. We can say that 1.4 90 hp is a chronic problem. As you say, it is usually with a throttle. You have done many things to do. Did you change the vehicle's oil sensor. There may be a problem with electrical wiring or sockets. If you are in Ankara, there is a Mas Peugeot and if you want, show them there, both electricians and mechanics are good. [/ QUOTE]
Thank you, I'll take the car there
08.05.2020 21:28 # 6
ismailkaya
This engine version also causes a fluctuation in the idle or stop in the gasoline, and this causes the oil and stop text to appear and disappear on the screen. When the LPG is installed, this problem becomes more pronounced, and the stop results in a direct stop. When it comes to the computer, it does not show any malfunction code, even if the engine is inserted, the valve that replaces the plug-in replacement valve, the catalyst is butterfly defective and the coil spark plug replacement software is whatever comes to your mind. If you find a remedy, can you share it from here?
08.05.2020 21:28 # 7
zerzevat
Is the 1.4 90hp engine in the 207s the same engine?
There is no idling problem, but there is an oil lamp issue when it gets hot ... I suspect eccentric bearings.
Who is this top secret friend and the solution he finds is also top secret?
03.07.2020 13:58 # 8
pluviofil
Unfortunately, the oil switch and its installation have changed and the problem continues, although not as often as before.
04.07.2020 16:46 # 9
ismailkaya
Friends with 1.4 16v 90 HP motor vehicle. We will try to help friends who have problems with LPG or gasoline.
04.07.2020 17:33 # 10
34pejo34
Please share bro if you find a solution to this problem
