1.4 My HDI 307 fell out of traction?
08.05.2020 14:15 # 1
dieselbastard
My vehicle is getting up very slowly while pulling from the traction. Lost the serial departure. Thank you for your help. The engine maintenance of the vehicle has just been done.
08.05.2020 14:15 # 2
peugeotefe
Did this malfunction occur after the engine maintenance was performed, does any malfunction light come on?
08.05.2020 14:15 # 3
dieselbastard
no malfunction lamp lights up before engine maintenance was done, we did the same, we got up the same again, bulky
08.05.2020 14:15 # 4
peugeotefe
the timing set of the vehicle has changed?
When did this malfunction come to you, it was the place where it stopped, or it was after compression
peugeotef to 2010-05-12 23:29:24
08.05.2020 14:15 # 5
dieselbastard
the timing apricot has changed has not changed as a set
08.05.2020 14:15 # 6
peugeotefe
I want to tell you that this fault occurred after doing any action on your vehicle or it suddenly happened like this.
08.05.2020 14:15 # 7
dieselbastard
No, after the operation, not suddenly it happened suddenly, tell me, let me tell you, when my brother bought this vehicle from Istanbul, he told me that he was more agile in series and departures. But since I used this car, the same has never changed. But for my brother, as I said before, his seriality and agility in departures have been lost. I do business according to his words, frankly, I did not have the chance to try other 1.4 HDIs, others do not know the same
08.05.2020 14:15 # 8
peugeotefe
it would be wrong to say something without using the tool
08.05.2020 14:15 # 9
Probably your brother used other tools or tools after giving you this tool.
08.05.2020 14:15 # 10
rifatseker
[QUOTE = kundun] Probably your brother used other tools or tools after giving you this tool, so if they are more serial [/ QUOTE]
:) I agree, I think we're talking about 1.4 HDI 307. Still, if you want to be very confident, I want to go to a dealer and take a test drive. If you have 1.4 hdi 307, I think this will delete the questions in your mind. After all, I do not know how accurate it is to act with someone else's insights.
08.05.2020 14:15 # 11
dieselbastard
Thanks (: but since we bought the 2nd hand in the vehicle 99 thousand, almost all the maintenance was done, I went to the turbo, which said that the turbo is in good condition, but I have injectors in my mind, should I have it cleaned?
08.05.2020 14:15 # 12
H-a-d-i
be a little relaxed. Search for a vehicle here and there. Even if your brother is not believing everything called ... I do not know if the injector maintenance km has come.
08.05.2020 14:15 # 13
msen63
Hello, the same problem has occurred in me. I do not think that the complaint of your friend and older brother is due to perception. I guess they couldn't express it. The problem with me was suddenly and very obvious. I had to climb the ramps with the 4th gear, and the 2nd gear. And this problem occurred when the car got out of service. So I went to the service due to another problem, but I came back with this problem. Unfortunately, although I went to the same service again and again, they could not find a solution. After the most recent operations, the car is now in normal traction in the 1st and 2nd gear position, it falls out of abnormal traction in 3, 4 and 5th gear, I can hardly get out of it with these gears. So only 3, 4, 5 gear works on straight road and landings. I have been a member of your forum just because of this problem and am looking for a solution. Thanks have a good day...
08.05.2020 14:15 # 14
peugeotefe
disassemble the camshaft of your vehicle and compare cams with a camshaft that you are sure is intact
08.05.2020 14:15 # 15
msen63
Hello, thanks for the answer. My vehicle is 1.4 and diesel. I asked the master who was interested in the car, he said that he did not touch the camshaft and could not be from it. I think the problem is related to the turbo circuit. Anyway, the problem occurred after a turbo-related repair. The story is as follows: The vehicle's air pollution prevention filter was very difficult to operate since it was full. The price of this filter was high, so I had the filter removed. This time, an unpleasant whistling sound occurred in the front of the vehicle. I went to the same master to cut this sound. They said that the sound came from the turbo and they lowered the sound a little, but they damaged the engine's oil hoses while removing and installing the parts, I had to return and return the vehicle before I could go a few km. Unfortunately, there was this problem when they renewed and delivered the oil hoses. The vehicle had been dropped by half.
08.05.2020 14:15 # 16
peugeotefe
I would like to have the camshaft checked by pressing on it, there is no turbo or electronic fault in your vehicle
08.05.2020 14:15 # 17
msen63
OK thanks. If you can give some more information on this subject, I would also be glad ...
08.05.2020 14:15 # 18
berko
1.4 hdiler gives such low performance. At least it's mine. I have their maintenance done prematurely and prematurely, I take the fuel from the same place, but from time to time the performance decreases in mine. I guess the air temperature, turbo and injectors are the reason for this. I shouldn't wear too much, after all, I go 1000 km to 1 warehouse :)
08.05.2020 14:15 # 19
tayfunyesilyurt
First of all Hello,
I hope my first message will be useful.
My 2003 307 1.4 hdi war.
I had the same troubles too. When I first bought it (2nd hand), I couldn't get any efficiency from the car. Though I was saying 1.4 68 horsepower 1.2 tons of vehicles but like that. Then I took it to Ankara's unswerving master.
The pipe connected to the engine has a small leg at the end of the pipe, it is an air measuring device. According to the air measured there, it was pumping diesel. When testing this device with a computer, the values were very low. After that, we put on a new piece for experimental purposes and the traction of the vehicle increased more than the actual. I did not replace the part, it was pretty dusty, I cleaned it with a lining cleaner, as a matter of fact, there is an electronic circuit inside. Now I am extremely satisfied with the performance of the vehicle. (While my father's 1.3multijet vehicle could not climb up to 60 with 60, now I see 80-90 with my own vehicle).
I also bought injector cleaner additive würth brand. My master suggested it to him, I think he contributed.
Maybe your problem is something completely different, but I think it is useful to show that piece.
Greetings
08.05.2020 14:15 # 20
msen63
My friend, thank you for your clarification, I am responding now for seeing it new. You said "the pipe that connects to the engine". Can you explain more about this pipe? Where is the engine, what is its function. And what exactly is the piece that is cleaned with the newly installed piece? If you can find out their name, it would be more acceptable because this is an important issue. This kind of thing causes a lot of people to cool down from their car. They are especially uncomfortable for those who have to go long ...
msen63 2010-06-24 04:44:20
Page : / 2
