1.4 HDI Turbo Lubricant
08.05.2020 17:30 # 1
Oaytekin
I wish everyone a good day. About 1 month ago, I had a routine oil and filter change. When I started the car in the morning without making 1000 km yet, I realized that the oil indicator on the screen decreased by one or two squares. I compared it with the dipstick as I thought it might be an indicator malfunction. The vehicle was really reducing oil. Interestingly, when I checked the gold before I got into the car, I didn't see any oil dripping on the ground. When I looked carefully at the engine at the end of that week, I saw that the top of the front tool housing was covered with oil. While checking here, I noticed that the flare pipe that lubricated the turbo was leaking and I made the way to the service. The master said that after 120.000km, that pipe must have changed in 307s. Since it sprays high pressure oil, it definitely creates cracks from top or bottom flares. We solved the problem by giving 80TL to 80TL and 30TL to a 15cm pipe. I wanted to write by thinking that it might be useful for friends who own diesel vehicles who have a similar oil reduction problem. In the meantime, I would recommend making a clamp to prevent the subject pipe from moving even 1 mm if possible. Good day everyone and pleasant driving.
08.05.2020 17:30 # 2
serkan719
Thanks for information.
08.05.2020 17:30 # 3
baroff
I have a fat reduction in 206, the master cleverly took a look at the crankshaft, he said, 500-600 cost him too
08.05.2020 17:30 # 4
Thanks.
08.05.2020 17:30 # 5
SDYMZ
My 206 also had the same problem, the turbo lubricant seemed to leak obviously, the master immediately replaced it with a new one.
08.05.2020 17:30 # 6
jack67
I made the change, I have a 1 finger length bour go and get it from the industry. I gave it 1 lira :)
08.05.2020 17:30 # 7
Oaytekin
Sir, I don't know the pipe in 206, but it is a Z profile pipe with a length of about 15 cm in 307. It was painful to give 80 lira, but it is not an equipment that can be purchased for 1 TL :) Frankly, I don't think that 206 minutes is finger length, but it can be. Anyway, let's connect the issue by saying the function, not the size, which is important :) I wish everyone a pleasant ride again.
08.05.2020 17:30 # 8
emre_akdag
08.05.2020 17:30 # 9
Gokhan Cetin
Thanks
