1.4 hdi traction problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:51 # 1
tolga0606
Hello friends, when the vehicle 1.4hdi vehicle engine is cold, the traction is fine, but after the engine warms up, the traction of the vehicle drops, is there any problem?
08.05.2020 20:51 # 2
GokhaN
If there is an abnormality in the normal operation of the vehicle, open the hood. Look at the condition of the turbo hose, do you have any torn skews etc.
08.05.2020 20:51 # 3
tolga0606
[QUOTE = GökhaN] If there is an abnormality in the normal operation of the vehicle, open the hood, let's see the oil leak on the right and it looks like a turbo problem. Look at the condition of the turbo hose, do you have any torn skews etc.
There is nothing when it doesn't work, I don't think the robust vehicle will be 55 thousand turbo in the hoses, but
08.05.2020 20:51 # 4
The first problem that comes to my mind is the flow meter and turbo electro valve -
08.05.2020 20:51 # 5
tolga0606
[QUOTE = sonerkyl] The first problem I can think of is flow meter and turbo electro valve - [/ QUOTE]
My brother had a problem with the valve, when the vehicle exceeded 3000 thousand, the engine failed, I changed the valve, the problem was solved. Where is the flow meter?
08.05.2020 20:51 # 6
[QUOTE = tolga0606] [QUOTE = sonerkyl] The first problem that comes to my mind is the flow meter and turbo electro valve - [/ QUOTE]
08.05.2020 20:51 # 7
KILIC
In addition to what the friends say, there may be torn hoses in the air filter hoses and the pressure pad is about to run out.
08.05.2020 20:51 # 8
tolga0606
[QUOTE = KILIÇ] In addition to what the friends say, there may be torn claws in the air filter hoses and the pressure pad may be running out.
My mind came to my mind when the pressure came to the pad, it was noticed by the friend as it was grasping from above but when 55 thousand pressures are finished
08.05.2020 20:51 # 9
Printing can end in 55 thousand, due to the user.
08.05.2020 20:51 # 10
onlycihan
I think 50 thousand km in the traffic of the central provinces is a very good figure.
08.05.2020 20:51 # 11
KILIC
[QUOTE = tolga0606] [QUOTE = SWORD] In addition to what the friends say, there may be torn hoses in the air filter hoses and the pressure pad is about to run out.
If the foot is always on the clutch, it will be finished in 30 thousand again.
08.05.2020 20:51 # 12
tolga0606
I understand, thank you everyone
