1.4 hdi Traction Problem ...
08.05.2020 20:06 # 1
xXxZzz
Hello ... 1.4 hdi 206 I had a problem with traction in my car recently. My car does not eat gas. Air Box Gauge and Pressure lining seems to have no problem with the new Turbo. The speed of 130-140 Km does not exceed the flat road. Although I have been to many masters for the last 1 month, they cannot detect any results. Thanks for your help in advance ...
08.05.2020 20:06 # 2
Selox
I think continue the simple ways. It's cold. 5W40 Add oil If the thick oil is added, the turbo may not work well and replace the oil filter. Replace diesel filter and Air filter as well. I hope that after that, if there is no other problem, I hope it will be fixed.
The diesel filter may not be able to act.
Selox 2016-12-23 13:48:25
08.05.2020 20:06 # 3
xXxZzz
3,000 km ago, routine maintenance was done, but I have not changed the diesel filter for 30 thousand km. The last reflection was that they put a diesel filter on it. xxxzzz 2016-12-23 18:54:06
08.05.2020 20:06 # 4
Selox
I think then from the diesel filter. These cars don't like the side industry, brother.
08.05.2020 20:06 # 5
muratsandalci
It seems to be the only responsible diesel filter. A filter that should change every 20,000 anyway.
08.05.2020 20:06 # 6
Narkotik
Unplug the air flow meter, test run, if there is a difference, the sensor is dirty
08.05.2020 20:06 # 7
ggitaristt
It sounded like a MAF sensor to me .. But 120-130 speeds corresponds to 3000 revolutions in 5th gear, so it looks like working in car protection ..
08.05.2020 20:06 # 8
xXxZzz
I tried to unplug the Air Flow Meter. Nothing changed. They've already changed. They Made a Contribution to the Diesel. In 4th gear, I take the car up to 120-130. Thank you to the friends who are interested in replacing the required filter and my printer as soon as possible ...
08.05.2020 20:06 # 9
ggitaristt
Friend, does your car pass 3000 cycles first? Can it convert 5000 cycles to pressure?
There is a possibility that the new changing part is incompatible or damaged, but I don't think so.
I had heard from someone before they could not find the same problem the world made cost. The mechanic says the turbo is normal, when the car stops, when the gas is pressed, the hoses swell. But on the way, the car faints. It does not exceed 120, it slows down on slopes. When he replaced the turbo solenoid valve, which they said was intact, his car was used.
08.05.2020 20:06 # 10
xXxZzz
The car does not have a problem with Turning. When I have the opportunity, I will also ask him if he is not noticed in the city, but he gets upset on the long road.
08.05.2020 20:06 # 11
berkayakulker
One of the most urgent fuel cleaner engineers.
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/wurth-cr-dizel-yakit-sistemi-ve-enjektor-temiz-227234417
