1.4 HDI Oil Selection ??
08.05.2020 14:17 # 1
dieselbastard
My vehicle 307 1.4 Hdı oil change has come, which oil brand do you recommend? Some of my research said 10W40, 5W40 Fully Synthetic, said 0W40, I was unstable?
08.05.2020 14:17 # 2
coyote26
Castrol Magnatec 10W / 40 Diesel ....
08.05.2020 14:17 # 3
cerci07
repairing peugeot 5w40 ford 5w30 for 1.4hdi
10w40 i never try
08.05.2020 14:17 # 4
badcombatant
[QUOTE = cerci07] peugeot recommends 5w40 ford 5w30 for 1.4hdi s
10w40 i never try [/ QUOTE]
I don't have any idea but why don't you recommend 10/40 engine oil for 1.4 hdi in my car I use
08.05.2020 14:17 # 5
msen63
I have 307 1.4 hdi`s. I put 0x40, the difference is obvious. As far as I know, the oil number becomes thicker as the oil number grows. It moves harder as it gets thicker, or more precisely, making the movement of the parts difficult because its slipperiness decreases. So I always say the best is 0x40. Allegations such as subtraction are just stories. Could it be more important than the performance of the engine even if it makes a reduction? As you drop, you will complete and end ...
08.05.2020 14:17 # 6
turbo27
I have joined you, first of all hello to everyone..I recommend you to use quality and blended brand oil before the oil number you will add to your engine .. 10-40 and 5- 30 & nbsp; oils, hdi and more are suitable for new generation diesel engines ...
08.05.2020 14:17 # 7
total 7000 10/40
08.05.2020 14:17 # 8
cerci07
[QUOTE = badcombatant] [QUOTE = cerci07] peugeot recommends 5w40 ford 5w30 for 1.4hdi s
not having any idea but why 10/40 for 1.4 hdi do not recommend engine oil I use it in my vehicle
http://www.castrol.com/castrol/iframe.do?categoryId=9032363&contentId=7059388
here you can learn the recommended oil for your vehicle
08.05.2020 14:17 # 9
alpbeyazi
Hello after a long break ...
first of all, I use 5w-40 castrol in my 1,4hdi vehicle.
08.05.2020 14:17 # 10
dbmaster
I know this on mobile 1 (0 - 40) I use this oil vehicle 1.6 110 HDI 307 & nbsp;
08.05.2020 14:17 # 11
I think 5 w40 is good, the oil is so thin, the better it would be for the diesel mortor
08.05.2020 14:17 # 12
dogu
You say the brands well, but when you take the car to the service, they do not put any other than the total "Don't
08.05.2020 14:17 # 13
Putting oil in the service is not a matter of mind anyway. They are putting the bidet is twice as much as the bidet's price.
08.05.2020 14:17 # 14
kabus
Castrol Magnatec 10W / 40 Diesel I use it in my car, I am very satisfied, meanwhile, I have one more recommendation for you. href = "http://shop.wurth.com.tr/araciniz-icin-urunler/common-rail-mazot-katkisi-300mml" target = "_blank"> http://shop.wurth.com .tr / vehicle-to-Price products / common-rail-diesel-contribution-300mml
08.05.2020 14:17 # 15
GokhaN
I use 10 40 diesel. We put PO oil on my last vehicle. I am satisfied with the price in general.
08.05.2020 14:17 # 16
ali oncu
I put 10 to 40 mobiles on my 1.4 diesel vehicle, but I'm glad that castrol was better in general
08.05.2020 14:17 # 17
sacooo
friends, when I read the subject, first of all, the oil you have used in your vehicle is important when choosing oil. You should pay attention to whether the oil is fully synthetic or semi-synthetic other than the numbers. 1.4 or 1.6 HDI vehicles are not performance vehicles. however, it will be best to continue with 0-40 or 5-30 or 10-40 whichever has been used in your engine before. The engine should continue with the oil used in the running-in phase. For example, if you put 0-40 oil in a vehicle using 10-40 engine oil, the oil will be thin (hence friction will increase, the temperature will increase) and the performance will decrease and fuel consumption will increase. Support should be obtained from services or real oil sellers. The most important point to be considered in this regard will be the selection of fully synthetic or semi-synthetic oil.
