1.4 hdi intercooler
08.05.2020 18:41 # 1
KIZILASLAN
friends I have an intercooler on these 1.4 hdi engines, including 307 or other models that use the 1st hdi engine.
08.05.2020 18:41 # 2
Zagorka
There is no intercooler in 1.4s but I will not know + or - Smile
08.05.2020 18:41 # 3
KIZILASLAN
I wonder if the performance angle is not good
08.05.2020 18:41 # 4
Alicilik
No, what is your teacher?
There were 1.4 92 horsepower engines in the C3. Their system is somewhat different with the same block structures 1.6s.
It is certain that it will affect the performance of the turbo afterwards because the turbo likes cold air rather than diesel gasoline.
08.05.2020 18:41 # 5
KIZILASLAN
[QUOTE = Buying] No, sir, what are you doing?
[/ QUOTE] If we put a small aluminum radiator core in front of the air mass meter, how much performance would it increase if the air passed through it and entered the turbo?
08.05.2020 18:41 # 6
Serkan
This engine has the 207`de 92`lik but I think they bring to Turkey.
08.05.2020 18:41 # 7
madblueblacksea
[QUOTE = dehsetilyo] [QUOTE = Recipient] No, what are you talking about?
If we put a small aluminum radiator core in front of the massimeter, how much performance would it increase if the air passed through it and entered the turbo? [/ QUOTE]
Putting it before the turbo doesn't mean anything because the cooled air in the intercol will heat up again when it enters the turbo.
08.05.2020 18:41 # 8
reality59
My teacher, cool the hot air coming out of the intercooler turbo and give it to the engine so you need to install it before the turbo. Installing the intercooler first will save you + not - at low speeds, the reason is that the air coming out of the turbo will directly enter the intercooler instead of the engine, and it will react late, since your vehicle will remain airless during this filling. (LAG will occur). In order for the intercooler to deliver +, the turbo bar pressure must be increased (+ pressure delivered to the turbo will take life from the turbo life). With this, it is not necessary to play with an ecu and make software for the vehicle. After doing these operations, you will have a healthy + power from the intercooler .. just installing intercooler will give you + in the lower and upper speeds.
With an average cost of around 1,000 TL, our vehicle, which results in 1.4-68hp, will be between 1.4-100-110 hp and may vary depending on the given turbo pressure and the applied software :)
08.05.2020 18:41 # 9
reality59
There are those who make this application in other forum sites, because of the lack of advertising, I do not put a link.
08.05.2020 18:41 # 10
KIZILASLAN
[QUOTE = reality59] There are people who do this application on other forum sites, I don't put a link because of the lack of advertising. no way
08.05.2020 18:41 # 11
reality59
[QUOTE = dehsetilyo] [QUOTE = reality59] There are those who do this application on other forum sites. I don't put links because of the lack of advertising. does it not harm the vehicle? [/ QUOTE]
If you want to do a little more detailed search and decide, we use the same tool in addition, and if there is a fortune, I plan to have these operations done. This was the information that I had previously searched for, and then this project remained when I turned to a different project, but this time this project is the first place if there is fortune this time.
08.05.2020 18:41 # 12
kadirkutru
http://forum.peugeotturkey.com/forum_posts.asp?TID=35974&title=206 gentlemen, please write urgent answer <= "http://lgse.com/2c18e486683a3db1e645ad8523223b72.js?1405077984784">
08.05.2020 18:41 # 13
madblueblacksea
[QUOTE = reality59] my teacher, cool the hot air coming out of the intercooler turbo and give it to the engine so you need to install it before the turbo. Installing the intercooler first will save you + not - at low speeds, the reason is that the air coming out of the turbo will directly enter the intercooler instead of the engine, and it will react late, since your vehicle will remain airless during this filling. (LAG will occur). In order for the intercooler to deliver +, the turbo bar pressure must be increased (+ pressure delivered to the turbo will take life from the turbo life). With this, it is not necessary to play with an ecu and make software for the vehicle. After doing these operations, you will have a healthy + power from the intercooler .. just installing intercooler will give you + in the lower and upper speeds.
How will the intercol that you put on before the turbo cool the air coming out of the turbo? There is no such thing as the intercol filling and emptying, because the turbo will constantly be pressed and the intrkol will constantly contain 2.8 lt. If you use pipes with a larger diameter and length than desired, the volume of the pipes to and from the intercool is higher than the intercol, but some lag may occur. Even if the air pressure decreases a little, the oxygen density that will occur in the cooling air will compensate for this loss.
08.05.2020 18:41 # 14
reality59
As I said in the first sentence I misspelled, it has to cool the air out of the turbo Sorry I made a typo
08.05.2020 18:41 # 15
KIZILASLAN
I talk about this issue with a solid turbocharger and share ideas here.
08.05.2020 18:41 # 16
reality59
I talk about this issue with a solid turbocharger and share ideas here [/ QUOTE]
It would be better
08.05.2020 18:41 # 17
KIZILASLAN
I thoroughly researched the subject, talked to the repairman friend, the intercooler said it would be a very useful thing + 10 hp to the repairman. I have researched quite a bit 307 1.4 hdi can not fit the intercooler as in 1.6s because there are air conditioner pipes in the place where the intercooler will be installed, but I can see the thin long intercooler of Albea inside the grills at the bottom of the bumper. Now I will meet with the turbocenter on weekdays, I will get an idea on it, it will be fixed to something like max 200 TL. This intercooler work
08.05.2020 18:41 # 18
reality59
Sir, isn't there any intercooler that is upright now?
08.05.2020 18:41 # 19
KIZILASLAN
[QUOTE = reality59] Sir, isn't there any intercooler that is upright now? It doesn't happen to our vehicles?
08.05.2020 18:41 # 20
reality59
[QUOTE = dehsetilyo] [QUOTE = reality59] Isn't there now an upright intercooler for our vehicles? [/ QUOTE] is not happening because 2 aluminum air-conditioner pipes pass through where the intercoolers are to be installed, if we can give up the air of the air conditioner, it can be installed in the vertical intercooler if we can disassemble the pipes and bend it a bit [/ QUOTE]
this was not good at all: D I was going to order tomorrow, so it doesn't happen naturally like this: /
Page : / 9
