1.4 HDI EGR Cancellation
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 16:09 # 1
inceyasar
Greetings 1.4 I have explored the cancellation process of the EGR Valve in HDIs and applied it on my own vehicle very easily. 1.4 TDCi also use this method in ford & nbsp;
08.05.2020 16:09 # 2
The main purpose of the EGR valve is to prevent the combustion temperature from exceeding a certain value (2500 Fahrenheit = 1371 degrees). Because it has been scientifically proven that atmospheric nitrogen gas interacts with oxygen on the temperature, forming a NoX (nitrogen oxide) compound, which plays the first place in composite environmental pollution. To prevent this compound from forming, the combustion temperature is kept below this threshold value. This heat is seen by the EGR valve. The EGR valve is located between the exhaust manifold and the intake manifold. By giving a very small amount of exhaust gas to the intake manifold, it passes the exhaust gas back into the system.
After this information, I should say the presentation that you have come to an application that can be expensive because of the assy. The efficiency you get as a result of this process cannot exceed 2-3 hp and this amount is not a noticeable increase by the driver. & Nbsp;
08.05.2020 16:09 # 3
sedataksu
Let me introduce I'm new member in the promotion bulundum.kısa, again step Sadat 34 years old istanbul oturuyorum.1.9 diesel vehicle got Arai Me EGR cancellation myself yaptım.eg the cancellation of so much surplus behalf of linking institutions of the car's engine, although powering a necessary uygulama.türkiye Located fuel quality European norms new reach it began was when I bought the vehicle in my Egrn's what it had known tool was made in 2005, because after seeing 40 thousand km resulting soot in the vehicle's intake manifold is really necessary insistently recommend ederim.türkiye some & nbsp; vehicles were sold off Egr.
08.05.2020 16:09 # 4
inceyasar
Koliva buddy status known're right fuel in turkey is a very wrong move for maybe the environment, but my car in my opinion not to be underestimated as much as we have observed that a performance increase sedate my brother as reno, and Ford's in some models EGR heard that the valve can be software sold off
08.05.2020 16:09 # 5
inceyasar
by the way & nbsp; egr cancellation & nbsp; only & nbsp I have read that provides an increase in performance in diesel vehicles, there is not much difference in gasoline in a place, instead of a decrease in performance
08.05.2020 16:09 # 6
sedataksu
The reason for this is that the way the diesel and gasoline engines burn is different. When Egr is activated, it sends exhaust gas to the engine, choking the engine and decreasing the heat of the engine.
08.05.2020 16:09 # 7
inceyasar
The revival after canceling the EGR valve affects me a lot.
08.05.2020 16:09 # 8
DS002
So what did you clog about, I am thinking of making it there?
08.05.2020 16:09 # 9
inceyasar
clogged with rotring pencil cap :)
08.05.2020 16:09 # 10
samet2461
[QUOTE = inceyasar] I clicked with a rotring pencil cap:) [/ QUOTE]
THAT is fine & nbsp; "Big & nbsp ;. faber castell also happens & nbsp; "Big.
08.05.2020 16:09 # 11
jack67
206 1.4 Does anyone know where hd de egr? I couldnt find it _?
08.05.2020 16:09 # 12
DS002
Does this process cause the black smoke to smoke?
08.05.2020 16:09 # 13
inceyasar
No black smoke problem to your information
