1.4 hdi diesel filter cleaned vehicle did not work
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:53 # 1
berkayymc
I am a new member of the forum. I changed the diesel filter in front of the house. I guess I made the air. My question is how can I get the air from the engine?
08.05.2020 20:53 # 2
berkayymc
https://i.hizliresim.com/2amM5O.jpg buda engine picture
08.05.2020 20:53 # 3
onlycihan
If you made a half-starter 4 to 5 times without starting the starter and switched off the ignition, there will be no fuel to pump the fuel, the injectors have not yet come.
08.05.2020 20:53 # 4
First of all, welcome to us. If you press on the place marked with red in the picture, you will get the air from there. Of course, unplug the green-tip hose I drew in yellow and get the air like that. When the press comes with diesel when disassembled, immediately insert it and pump a little more.
08.05.2020 20:53 # 5
berkayymc
Hodja, now I have come to the industry. I will write again when I try to find and ask the master. Thank you for your answer.
08.05.2020 20:53 # 6
berkayymc
The friends came to the master, unscrew the exit hose of the turbo, sprayed the lining of the lining, took it in a few anthems, no problem.
08.05.2020 20:53 # 7
get well hodja.
08.05.2020 20:53 # 8
berkayymc
Thanks
