1.4 hdi 206 oil burning
01.05.2023 21:37 # 1
mahmut alpay
Hello, I have a diesel car with 280,000 km mileage. It burns 1 liter of oil in 5,000 km mileage. I see blue smoke when loaded or when loaded without warming up. I wonder if it is from the turbo or the piston ring. I don't know exactly, or both. The mechanic said there is a slight gap in the turbo shaft, but he said it is not that. I used Shell Total oil. I don't want to put 1060 oil. It will damage the oil pump. I just changed that too. What do you recommend? I also see sweating in the turbo pipe. I need your help about piston rings or turbo. I wish you safe driving.
05.05.2023 22:50 # 2
1e1b
Sir, don't mess with oils like 10w60. Don't use anything other than 5w30 and 5w40 for an HDI engine. Don't load the car until it's warmed up. Have a reputable mechanic check it. There might be a simple reason.
06.05.2023 00:25 # 3
Berkay Erdinc
Have a compression test done on your vehicle. This test will tell you whether the oil burning is due to the turbo or the piston rings.
