1.4 engine 206 automatic gear
08.05.2020 15:07 # 1
saw50
friends 1.4 engine 206 auto cars gas burning, especially if you inform about the amount of fuel in the city I would be happy
Thanks sincerely...
08.05.2020 15:07 # 2
UGuRs
Tupte 330 cut burns my vehicle
08.05.2020 15:07 # 3
ekinoks44
mine also burns around 270 lpg.
08.05.2020 15:07 # 4
kurt1604
my kide burns 21 cents in city between 27 cities in lpg
08.05.2020 15:07 # 5
kizilhakan
my friend, I'm going 200 km with 100 TL gasoline, you make the account al4 triptonic gearbox :))
Although I tried to use an economic note?
08.05.2020 15:07 # 6
Onur
The essence of the job is that it burns very little, it burns 10 lt in gasoline
08.05.2020 15:07 # 7
ramtas
I have 1.6 307 automatic 100km at 10.6 never broke down
08.05.2020 15:07 # 8
UGuRs
[QUOTE = kurt1604] my kide burns 21 cents in the city between lpg in lpg [/ QUOTE]
What is the brand of the tube?
08.05.2020 15:07 # 9
kurt1604
atiker brother
08.05.2020 15:07 # 10
UGuRs
If I change it too, I wonder if it would fall: S
08.05.2020 15:07 # 11
saw50
Thank you for your information, friends, but it seems that auto-gasoline always burns the engine very much.
08.05.2020 15:07 # 12
C!N
The fuel values of the vehicle vary according to the city you live in.
I live in Zonguldak; you know, surely, a small city with lots of hills. It takes a maximum of 10 minutes to go from place to place in the city by car. You have to give too much gas on the slopes, and the vehicle burns in parallel. I burn between 0.27-0.33 TL per km in such a city (LPG = 2.25TL)
When I went to Ankara last month (January 2011); Since I filled the warehouse on my way, my daily km counter showed 280 km. I entered the fuel station again and filled my tank and bought fuel for 45 TL (it was something like LPG = 2.13 I guess I'm not quite sure in Ankara). This shows that I have traveled 280 km to 45 TL between Zonguldak and Ankara, and this value corresponded to 0.160 TL per km. Before I set off again, I reset my daily km counter to calculate my urban consumption in Ankara.
My daily km counter was showing 65 km when I entered the station to fill my warehouse when I was about to set off my work in Ankara and start off again. When my tank was full, the pump was showing 11-odd TL, and we completed it for 12 TL with a bit of compression. In other words, I have traveled 65 km for 12 TL in Ankara, which means that I burned approximately 0.185 TL / km of LPG in the city.
As it can be understood from the examples that I have given to friends, the city values vary with each, we can only evaluate the normal or abnormal evaluation according to the peers in that city. As in my experience, the vehicle that burns 0,33 TL / km in one city can burn 0,185 TL / km in another city. This means almost twice the difference.
Meanwhile, my car Peugeot 206 1.4 8v 75 PS BVA, 2009 model 26k km`s maintenance is a complete vehicle. I hope I could help.
08.05.2020 15:07 # 13
UGuRs
This is why it is due to the baaya baaya :( Thank you for your comment
08.05.2020 15:07 # 14
metin
[QUOTE = ramtas] I have 1.6 307 automatic 100km at 10.6 never went below thank god
ramtas is already 10.9 in the city and because the weather is cold, it usually rises above this value.
08.05.2020 15:07 # 15
automatic transmission increases fuel. Although 1.4, the numbers are very high. but its automatic shape makes this figure normal. According to the place of use, it changes according to the place where the gas is pressed. But if this temperature is considered thermally, it is very normal to burn 11 lpg grandfather if it burns 10 on gasoline.
Our friend of Kızılhakan has written 100 TL: 200km = 50 kr / km buda which is approximately 12.5 lt.
the cecol 2011-02-22 11:21:59
08.05.2020 15:07 # 16
kizilhakan
I had a serious maintenance, I got it connected to the computer, so on average, the number of computers on the computer is correct, I endure because we are lpg, and the winter data of Istanbul that I wrote is a bit better in the summer, like 260 270 km, but these are friends.
08.05.2020 15:07 # 17
[QUOTE = kizilhakan] I have had such a serious maintenance, I got it connected to the computer, on average, it gets a lot more on the computer, the values are correct, I endure because we are lpg, and this is what I wrote, the winter data of Istanbul is a little better in summer, like 260 270 km, but these are friends. [/ QUOTE]
If you are not too slow, you are not in too much traffic, or you have a lot of traffic in your transmission
08.05.2020 15:07 # 18
maslakpeugeot
slm dude I have a program of 275 lira. I have a good program if you are in Istanbul, I can guide you on my phone call me.
08.05.2020 15:07 # 19
UGuRs
the guy I bought said it goes 100 km with 20 pounds i bought 55 with 20 pounds i see 60 hard I get the liter from 1.93 but they said it was normal again
If I wear cem atiker or any other tube, will this figure change: S
08.05.2020 15:07 # 20
metin
[QUOTE = UGuRs] the man I bought said 100 km with 20 lira I bought it 55 with 20 lira I go 60 I see 60 hard liter I get it from 1.93 but they said it was normal again.
If I put cem atiker or another tube, will it change: S [/ QUOTE]
I have an automatic 307. I made a road with 20 TL in the city and 64 km. I guess it's too much for you to have 206 although the case is lightweight.
Meanwhile, an atiker inline system is attached.
Page : / 4
