1.4 engine 106 oil amount
08.05.2020 19:23 # 1
ibanez_022
Guys, I had periodic maintenance today. I know that 1.4 engine 98 model 106 3.5 liter oil should be put, I know the master put 4 liter. I thought that there would be nothing from 0.5 liters. When he pulls the dipstick, he is very on the line. can i get your comments
08.05.2020 19:23 # 2
Open excess oil by opening the crankcase plug. a simple operation you can do yourself. I don't know if the damage will happen, but the engine will over time. do not say what happens, bring it back to normal level
08.05.2020 19:23 # 3
ibanez_022
Now I went and bought the aquarium hose, I will pull the oil stick with it :)
08.05.2020 19:23 # 4
ibanez_022
[QUOTE = sonerkyl] open the excess oil by opening the sump plug. a simple operation you can do yourself. I don't know if the damage will happen, but the engine will over time. Do not say what happens, bring it back to normal level [/ QUOTE]
There's something like a crankcase under the car or something. I can't get under the car :)
08.05.2020 19:23 # 5
outlaw
LIKE THE DAMAGE OF THE OLD OIL, I HAVE THE DAMAGE OVER THE NORMAL STANDARD.
WHY THE MEN WERE THE MAXIMUM POINT IN OIL BAR ???
08.05.2020 19:23 # 6
ibanez_022
[QUOTE = outlaw] TAKE OUR OWN DAMAGE OVER THE NORMAL STANDARD AS DAMAGING THE DAMAGER OIL DAMAGE AND TELL THIS REPAIRER IN A MORE ...
Actually, it was not a bad mechanic but a dialogue between us;
I went to 170-180 km speeds with the vehicle 2-3 times to try and less oil decreased each time. but if I go normal 100-120 or something, it doesn't decrease. I said this to get an idea. He may not have said anything, he said.
After replacing the air filter, he saw some oil in the black plastic box of the air filter and said that your car is burning oil.
I said no, I don't think it is up to you. He may have put too much in mind that he is burning fat. When I put the oil, I said, let's put it in 3.5 liters. He said, the oil filter has also changed.
At that moment it made sense, I did not say anything, I wondered it looked pretty much.
I poured a half liter still looks more
08.05.2020 19:23 # 7
muro_60
factory values
08.05.2020 19:23 # 8
ibanez_022
[QUOTE = muro_60] factory values
Teacher, I saw 2.9 Lt, it was writing 3.0 with the filter
ibanez_022 2015-08-04 10:00:37
08.05.2020 19:23 # 9
muro_60
Don't look at the internet, this is the data
08.05.2020 19:23 # 10
ibanez_022
writes in the manual not on the internet
08.05.2020 19:23 # 11
ibanez_022
http://documentation.peugeot.com/pmdmydocfiles/doc05-01/donnees/106/ed03-01/lg_tr_tr/htm/index_94_106-tu-ed03-2001.htm
08.05.2020 19:23 # 12
muro_60
I heard it for the first time in 3 lt opener
08.05.2020 19:23 # 13
ibanez_022
Did you click on the link I threw?
08.05.2020 19:23 # 14
muro_60
Yes, I looked at the data I looked at according to your data 1.6.
08.05.2020 19:23 # 15
erenahmet95
I know that it will overheat.
edit: that's it in my car. It turns out, my brother changed the oil, he said normal. but still doubt this situation.
erenahmet95 2015-08-04 15:51:54
