1.4 e-hdi Particle Filter filling error
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 21:12 # 1
berkayymc
Good day, my friends, I got the particle filter filling rate see the booklet warning, and my service and engine malfunction lamp burned.
08.05.2020 21:12 # 2
darkiron
On the right side of the highway, go for a while at high speed in 2nd or 3rd gear. The filter will clean itself. If the warning does not go, you can clean it from the industry.
08.05.2020 21:12 # 3
samet2461
In my 308 1.6 e-hdi, I get this error once in a while (danger of clogging the particle filter, please follow the suggestions) and the remedy is as follows;
You will use your vehicle on a straight road, ALL THE SAME PERIOD. If you take your foot off the accelerator while the speed is stationary, you will immediately see that it has caused the malfunction. the speed is over 100km / h and so I travel 5 minutes. Then I put the 6th gear and relax the vehicle. I don't see that fault for a long time
samet2461 2019-04-18 08:25:11
08.05.2020 21:12 # 4
The reason for this is that the filter due to the constant short distance usage cannot clean itself. As our friends say, use low gear, high speed 10-15 minutes will improve.
